- To:
- Subject: Re: [cgal-discuss] Error CGAL
- Date: Sat, 5 Apr 2014 09:26:22 -0700 (PDT)
I have given command line input as g++ -lCGAL -lgmp and it worked well for the first two cases i.e demos and "Getting started" example but for this it is not working inspite of giving the same command
On Sat, Apr 5, 2014 at 9:43 PM, Marc Glisse [via cgal-discuss] <[hidden email]> wrote:
On Sat, 5 Apr 2014, Alexander wrote:> Hello Friends,
> I am a new CGAL users and I request your help regarding the problem I am
> facing
> I have run the demos and "Getting Started" example successfully but when I
> tried to run this example in UBUNTUWhat do "I have run" and "I tried" mean in terms of exact commands you
typed? We can't say what you did wrong if we don't know what you did...> http://doc.cgal.org/latest/Triangulation_2/Triangulation_2_2triangulation_prog1_8cpp-example.html
> I run into the following problems which I assume are linking errors and I am
> unable to resolve them even after looking up on the web.Missing -lCGAL, but if you are using cmake as recommended in the doc, it
should handle that for you.
Marc Glisse--
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Error-CGAL-tp4659074p4659075.html
SRIVASTAVA
View this message in context: Re: Error CGAL
- [cgal-discuss] Error CGAL, Alexander, 04/05/2014
- Re: [cgal-discuss] Error CGAL, Marc Glisse, 04/05/2014
- Re: [cgal-discuss] Error CGAL, Alexander, 04/05/2014
