- To:
- Subject: Re: [cgal-discuss] Error CGAL
- Date: Sat, 5 Apr 2014 18:37:50 +0200 (CEST)
On Sat, 5 Apr 2014, Alexander wrote:
I have given command line input as g++ -lCGAL -lgmp and it worked well for
the first two cases i.e demos and "Getting started" example but for this it
is not working inspite of giving the same command
"g++ -lCGAL -lgmp" is not the exact command you typed. You also put the file name somewhere, etc. And yes, where you put the file name can matter (it should be before all -l flags). So please don't try to be clever and take shortcuts, just copy-paste the exact commands.
Marc Glisse
- [cgal-discuss] Error CGAL, Alexander, 04/05/2014
- Re: [cgal-discuss] Error CGAL, Marc Glisse, 04/05/2014
- Re: [cgal-discuss] Error CGAL, Alexander, 04/05/2014
