cgal-discuss - Re: [cgal-discuss] mingw64|win32 issues
  • To:
  • Subject: Re: [cgal-discuss] mingw64|win32 issues
  • Date: Fri, 11 Apr 2014 17:29:28 +0200
Le Thursday 10 April 2014 08:38:59 xantares 09 a écrit :
> 3. Export libraries (.dll) are properly installed to <PREFIX>/bin and import
> libraries (.dll.a) to <PREFIX>/lib. But in the CGALConfig.cmake file, the
> CGAL*_LIBRARY vars refer to the export library name in <PREFIX>/lib:
> set(CGAL_LIBRARY "/usr/i686-w64-mingw32/lib/libCGAL.dll")
> it should simply be:
> set(CGAL_LIBRARY "CGAL")
> as CGAL_LIBRARY_DIRS is used by UseCGAL, which is also a lot cleaner.
> Same for other CGAL*_LIBRARY vars.
I disagree. Our UseCGAL file should not use link_libraries with
CGAL_LIBRARY_DIRS, and should use imported targets, with full path to
libraries.
Laurent Rineau, PhD
