- To:
- Subject: Re: [cgal-discuss] Simplification: selection process and constrained edges
- Date: Fri, 11 Apr 2014 20:44:42 -0700 (PDT)
I tried a bigger mesh of 100k facets, and due to the bijectivity constraints
that I put in the placement, I couldn't simplify below 22k facets. I went
again over the source code, and I can't see any place that inserts edges
(e.g. in the 2-ring of a collapsed edge) back to the queue. Meaning, once an
edge is out of the queue it won't get back to it.
Can you please confirm, and explain what you meant by getting back to queue?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplification-selection-process-and-constrained-edges-tp4659059p4659112.html
- [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Sebastien Loriot (GeometryFactory), 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/12/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/13/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Sebastien Loriot (GeometryFactory), 04/14/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/14/2014
