- To:
- Subject: Re: [cgal-discuss] Can someone write an application?
- Date: Thu, 17 Apr 2014 12:28:06 +0100
Hello,
I just thought I would chime in, because I was interested in using the 3D Surface Mesh Generation module myself. A couple of problems I had with using it was that 1) It wouldn't work with the EPEC kernel 2) The examples all seem to rely on the grey level image (.inr) format, which there doesn't seem to be any nice libraries (in CGAL) for working with this format, all though I did find this: https://github.com/cgogn/CGoGN/blob/master/ThirdParty/Zinri/Zinrimage.h
What I would like is some examples where I can just mesh a std::list of CGAL::Point_3
Regards,
Giles
On 17 April 2014 06:14, Sebastien Loriot (GeometryFactory) <> wrote:
Did you have a look at
http://doc.cgal.org/latest/Surface_mesher/index.html#Chapter_3D_Surface_Mesh_Generation ?
Sebastien.
- [cgal-discuss] Can someone write an application?, EvgenyG, 04/15/2014
- Re: [cgal-discuss] Can someone write an application?, Sebastien Loriot (GeometryFactory), 04/17/2014
- Re: [cgal-discuss] Can someone write an application?, Giles Bathgate, 04/17/2014
- Re: [cgal-discuss] Can someone write an application for money?, EvgenyG, 04/18/2014
