[cgal-discuss] How to format my images in order to use 3D Surface Mesh Generation
- To:
- Subject: [cgal-discuss] How to format my images in order to use 3D Surface Mesh Generation
- Date: Thu, 17 Apr 2014 13:55:13 -0600
Dear CGAL users,
I have difficulty in using 3D Surface Mesh Generation. What I have is a set of binary images that is a mask of a porosity in an alloy. The user manual says that the 3D Surface Mesh Generation algorithm can work with 3D gray-level images, therefore I thought there was a way to send my images to the algorithm.
I looked at the source code located at \examples\Surface_mesher and found that it reads an image name "skull_2.9.inr". How can I struct my images in order to be able to work with this algorithm?
Thanks in advance.
Sincerely,
Xiaoxiong
- [cgal-discuss] How to format my images in order to use 3D Surface Mesh Generation, Xiaoxiong Xing, 04/17/2014
- Re: [cgal-discuss] How to format my images in order to use 3D Surface Mesh Generation, Giles Bathgate, 04/17/2014
- Re: [cgal-discuss] How to format my images in order to use 3D Surface Mesh Generation, Xiaoxiong Xing, 04/21/2014
- Re: [cgal-discuss] How to format my images in order to use 3D Surface Mesh Generation, Giles Bathgate, 04/21/2014
- Re: [cgal-discuss] How to format my images in order to use 3D Surface Mesh Generation, Xiaoxiong Xing, 04/22/2014
