- To:
- Subject: Re: [cgal-discuss] How to use AABB Tree correctly?
- Date: Wed, 23 Apr 2014 16:42:25 +0200
- Organization: NUMA Engineering Services Ltd
On 26/08/13 12:26, ChaoM wrote:
Hello Sartaj Hundal :<snip>
Thanks for quick reply.
A forward question: I want to know how the CGAL sovle the 3d boolean
opreation besides Nef, since i find Nef costs too many time , and I can not
understand how to use it.
If you did not want to use Nef, you can define a level set function and then use ImplicitDomainFunction (examples in docs) - assuming you can define inside or outside using the polarity (+/-), it is possible to combine this with an AABB tree distance search to get a continuous function sloping to the boundary (while I don't think that's necessary I assume the boundary search algorithm performs most efficiently for better behaved functions...?).
Phil
- Re: [cgal-discuss] How to use AABB Tree correctly?, TL3SHI2, 04/23/2014
- Re: [cgal-discuss] How to use AABB Tree correctly?, Sebastien Loriot (GeometryFactory), 04/23/2014
- Re: [cgal-discuss] How to use AABB Tree correctly?, lei tang, 04/24/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] How to use AABB Tree correctly?, Phil Weir, 04/23/2014
