- To:
- Subject: Re: [cgal-discuss] How to use AABB Tree correctly?
- Date: Thu, 24 Apr 2014 09:31:48 +0800
Is there any way that I can traverse the constructed AABB tree? Namely, I constructed two aabb trees for two meshes,
and traverse from the root node to detect if there's any intersection between nodes(first node intersection, then primitives detective).
2014-04-23 22:06 GMT+08:00 Sebastien Loriot (GeometryFactory) <>:
On 04/23/2014 03:55 PM, TL3SHI2 wrote:There is not. Throw an exception if there is an intersection and catch
Hi, Laurent Rineau
In the example of cgal
<http://doc.cgal.org/latest/Box_intersection_d/Box_intersection_d_2triangle_self_intersect_8cpp-example.html>
this line " CGAL::box_self_intersection_d( boxes.begin(), boxes.end(),
report_inters);"
I am wondering if there is a way that when detects one pair of primitives
intersect with each other, the intersection detection process stop. This
method seems won't stop until all the boxes iterated.
it.
Sebastien.
I want to know whether the given two meshes collide with each other. Is
there any way convenient in CGAL?
Laurent Rineau (CGAL/GeometryFactory) wrote
Le dimanche 25 août 2013 04:06:18 ChaoM a écrit :
Hello everybody:
Now i meet this problem: I have three models , these models are
simple geometric objecets. Such as: halfsphere, Clylinder, Cube and so on
All these models have the trianglated surface(that is , the surface of
the
models is made of a mount of triangles).
What i want to do is use the AABB Tree to get the intersection of
these three models. In my point , i do not use the AABB Tree correctly
,because i just use "do_intersect" function to judge a triangle of one
models if intersect a triangle of another models .
For your scenario, you better use the package named "Intersecting
Sequences of
dD Iso-oriented Boxes". The AABB package is best use when you have a bit
data
set of triangles that are fixed (the model), and a lot of intersection
queries
to it.
In your scenario, it seems that you have several models, that are fixed.
AABB
trees are not well adapted for that.
Laurent Rineau, PhD
View this message in context: http://cgal-discuss.949826.n4.nabble.com/How-to-use-AABB-Tree-correctly-tp4657967p4659186.html
- Re: [cgal-discuss] How to use AABB Tree correctly?, TL3SHI2, 04/23/2014
- Re: [cgal-discuss] How to use AABB Tree correctly?, Sebastien Loriot (GeometryFactory), 04/23/2014
- Re: [cgal-discuss] How to use AABB Tree correctly?, lei tang, 04/24/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] How to use AABB Tree correctly?, Phil Weir, 04/23/2014
