- To:
- Subject: Re: [cgal-discuss] Some CGAL 4.4 Bug Fixes
- Date: Sat, 26 Apr 2014 12:19:22 -0700 (PDT)
I am using VC10. I forgot for which it was (it was one of the Polyhedron
ones). I can check in a little later. However, the following if statement
has to be hit for this to occur:
if( POLYHEDRON_QTSCRIPT_DEBUGGER )
So maybe that one isn't happening. I can't figure where that is set, but it
happened by default in my setup (at least with a DEBUG build).
I actually haven't used the kinetic data structures yet, but might so I
wanted them to compile.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Some-CGAL-4-4-Bug-Fixes-tp4659159p4659205.html
- [cgal-discuss] Some CGAL 4.4 Bug Fixes, Jeffrey Bush, 04/19/2014
- Re: [cgal-discuss] Some CGAL 4.4 Bug Fixes, Jeffrey Bush, 04/22/2014
- Re: [cgal-discuss] Some CGAL 4.4 Bug Fixes, Andreas Fabri, 04/25/2014
- Re: [cgal-discuss] Some CGAL 4.4 Bug Fixes, Jeffrey Bush, 04/26/2014
- Re: [cgal-discuss] Some CGAL 4.4 Bug Fixes, Jeffrey Bush, 04/27/2014
- Re: [cgal-discuss] Some CGAL 4.4 Bug Fixes, Andreas Fabri, 04/24/2014
