cgal-discuss - [cgal-discuss] Shortest distance path between two points in a simple polygon
  • To:
  • Subject: [cgal-discuss] Shortest distance path between two points in a simple polygon
  • Date: Tue, 29 Apr 2014 17:18:48 -0700 (PDT)
Hi all,
I want to find the shortest distance path between two points in a simple
polygon without holes.
Could anyone guide me if there exists such an algorithm implemented in CGAL
? The implementation might not be optimal, thats Ok.
I came across the Rubber-band algorithm research paper but couldnt find any
existing implementation in CGAL or elsewhere. Please help.
Thanks in advance.
dg.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Shortest-distance-path-between-two-points-in-a-simple-polygon-tp4659225.html
