cgal-discuss - Re: [cgal-discuss] Shortest distance path between two points in a simple polygon
  • To:
  • Subject: Re: [cgal-discuss] Shortest distance path between two points in a simple polygon
  • Date: Wed, 30 Apr 2014 11:45:45 +0200
Hm
if perf is not really an issue,
seems you can do even simpler :
http://en.wikipedia.org/wiki/Euclidean_shortest_path
The idea would then be :
_1. build the intervisibility graph between all nodes of the polygon
_2. use disktra shortest path on it
I'm afraid 1. is out of question for polygons with many vertexes (polygon with n vertixes -> a graph with possibly n*(n-1)/2 edges)
Cheers,
Rémi-C
2014-04-30 11:32 GMT+02:00 Rémi Cura <>:
Hey,
Just an idea,
If there is a direct line between both points, easy.
Else :
break the polygon into triangles/convex parts (should be possible to scavenge that also).
http://doc.cgal.org/latest/Triangulation_2/index.html
http://doc.cgal.org/latest/Partition_2/index.html
Then you problem is much more simpler :
_building the 2D arrangement graph with all the triangles vertex, you are looking for the shortest path,
which you can solve using Dijkstra for instance (http://doc.cgal.org/latest/BGL/index.html).
Then it is almost over, you only need to optimize your path a bit by replacing some tuple of consecutive segment by one segment.
Cheers,
Rémi-C
2014-04-30 2:18 GMT+02:00 dg <>:
Hi all,
I want to find the shortest distance path between two points in a simple
polygon without holes.
Could anyone guide me if there exists such an algorithm implemented in CGAL
? The implementation might not be optimal, thats Ok.
I came across the Rubber-band algorithm research paper but couldnt find any
existing implementation in CGAL or elsewhere. Please help.
Thanks in advance.
dg.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Shortest-distance-path-between-two-points-in-a-simple-polygon-tp4659225.html
