- To:
- Subject: Re: [cgal-discuss] CGAL assertion error
- Date: Mon, 5 May 2014 06:28:58 -0700 (PDT)
Hi Sebastian,
Thanks for the reply. If that is the case, can you suggest some other
function where I can insert some points and get a surface back.
My situation is exactly as shown in the test sscce. I have a surface which I
want to remesh. There are two things I would like to control in the final
surface
1. A few points which I insert initially in the triangulation. I can
guarantee that these points will lie on the surface.
2. I want to control the size and angle of the resulting triangulation. I
can do this by facets_criterion.
Now the points which I have inserted in the triangulation will be, more
often than not, closer to each other than the size I have given in the
facets criterion (radii of surface Delaunay balls, center-center distance of
surface mesh facets).
Can you suggest any other function in CGAL which can robustly return the
surface back for these requirements? Thanks.
Regards,
Piyush Gupta
Piyush Gupta
UIUC
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-assertion-error-tp4659132p4659247.html
- Re: [cgal-discuss] CGAL assertion error, gupta61, 05/04/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] CGAL assertion error, Sebastien Loriot (GeometryFactory), 05/05/2014
- Re: [cgal-discuss] CGAL assertion error, gupta61, 05/05/2014
