cgal-discuss - [cgal-discuss] Squared distance on AABB tree of CGAL : precondition violation
  • To:
  • Subject: [cgal-discuss] Squared distance on AABB tree of CGAL : precondition violation
  • Date: Mon, 5 May 2014 08:18:37 -0700 (PDT)
Hello,
I've just discovered the AABB tree data structure and need, for each of my
topological operations, to compute the distance of the resulting point to
the mesh.
Thus, I use the squared_distance(Point) to get it after having successfully
build the tree.
And I receive this precondition violation message :
CGAL ERROR: precondition violation!
Expr: (squared_radius >= FT(0)) & (o != COLLINEAR)
File: /usr/include/CGAL/Cartesian/Sphere_3.h
Line: 57
The resulting point causing this should be on the mesh surface or not so far
(this should be an issue ?), is incident to many edges and be placed in a
dense, concave space of the surface. When I try with a constant distant
point, there no problem.
Have you any idea of what happen exactly ?
Can I really compute this so closed distance with an AABB tree ?
PS : I run it on ubuntu 12.04 with gcc-4.6.3 .
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Squared-distance-on-AABB-tree-of-CGAL-precondition-violation-tp4659248.html
