cgal-discuss - Re: [cgal-discuss] 3D Triangulation-Segment intersection
  • To:
  • Subject: Re: [cgal-discuss] 3D Triangulation-Segment intersection
  • Date: Wed, 07 May 2014 13:16:23 +0200
On 21/03/2014 14:45, Per Zetterlund wrote:
Hi all,
What is the best way to find which cells (or facets) of
a 3D triangulation that intersects a given line segment?
Interate through all cells (facets) and check for
intersection (how?) or trace the segment from the
start by going from heighbor to neighbor?
It depends of what do you mean by the best way.
The easiest to code is the former
The most efficient is the latter (as Andreas said):
if your points are random you get only n^(1/3) tetrahedra intersected by the line.
However, programming such a walk is painful in 3D, especially if you want to
code correctly all degeneracies.
If your line is defined by pq, when you enter a new tetrahedron abcd from face abc,
you can compute the orientations of qpad, pqbd, and pqcd to decide
by which face you exit the tetrahedron (and treat properly all cases where you intersect an edge)
Infinite tehtrahedron should not be a problem, you just stop walking.
