- To:
- Subject: Re: [cgal-discuss] 3D Triangulation-Segment intersection
- Date: Wed, 07 May 2014 13:38:37 +0200
Le 5/7/14 1:27 PM, Per Zetterlund a écrit :
Thanks!
On Wed, May 7, 2014 at 1:16 PM, Olivier Devillers
wrote:
Infinite tehtrahedron should not be a problem, you just stop walking.I'm afraid I have to be able to step from one infinite tetrahedra to another
via the infinite face.
The infinite tetrahedra are just a trick to maintain the convex hull of the points,
so a infinite tetrahedron is a kind of representation of the convex hull faces.
If you want infinite tetra, you should define precisely what does that mean for
an infinite tetrahedron to intersect a line.
- Re: [cgal-discuss] 3D Triangulation-Segment intersection, Per Zetterlund, 05/07/2014
- Re: [cgal-discuss] 3D Triangulation-Segment intersection, Olivier Devillers, 05/07/2014
