Re: [cgal-discuss] Squared distance on AABB tree of CGAL : precondition violation
- To:
- Subject: Re: [cgal-discuss] Squared distance on AABB tree of CGAL : precondition violation
- Date: Wed, 14 May 2014 20:59:49 +0200
On 05/05/2014 05:18 PM, fcaillaud wrote:
Hello,
I've just discovered the AABB tree data structure and need, for each of my
topological operations, to compute the distance of the resulting point to
the mesh.
Thus, I use the squared_distance(Point) to get it after having successfully
build the tree.
And I receive this precondition violation message :
CGAL ERROR: precondition violation!
Expr: (squared_radius >= FT(0)) & (o != COLLINEAR)
File: /usr/include/CGAL/Cartesian/Sphere_3.h
Line: 57
The resulting point causing this should be on the mesh surface or not so far
(this should be an issue ?), is incident to many edges and be placed in a
dense, concave space of the surface. When I try with a constant distant
point, there no problem.
Have you any idea of what happen exactly ?
Can I really compute this so closed distance with an AABB tree ?
PS : I run it on ubuntu 12.04 with gcc-4.6.3 .
What kernel are you using? Could you show how you are using the AABB tree?
Sebastien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Squared-distance-on-AABB-tree-of-CGAL-precondition-violation-tp4659248.html
- [cgal-discuss] Squared distance on AABB tree of CGAL : precondition violation, fcaillaud, 05/05/2014
- Re: [cgal-discuss] Squared distance on AABB tree of CGAL : precondition violation, Sebastien Loriot (GeometryFactory), 05/14/2014
