[cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex
- To:
- Subject: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex
- Date: Wed, 4 Jun 2014 03:23:24 -0700 (PDT)
I want to create a tetrahedral mesh which can have hole/cavity inside it(at
intermediate stages of computation in an algorithm). For this I am trying to
use Linear cell complex(LCC)
<http://doc.cgal.org/latest/Linear_cell_complex/index.html> :
I want to perform the following:
1. Compute intersection between a triangle and all tetrahedrons in LCC.
2. Remove all intersecting tetrahedrons from LCC.(which forms a cavity)
3. Replace them with another set of tetrahedrons.(these must be exactly
aligned with the cavity boundary, to completely fill the hole)
*For task 1:*
I need to traverse through all tetrahedrons. I do not find any iterator sort
of functionality for LCC. Do I need to use a standard graph traversal
algorithm over /beta_3/ links of darts to traverse all tetrahedrons?
*For Task 2:*
Here, I think /remove_cell()/ function has to be used to remove the
intersecting 3-cells.
*For Task 3:*
Although, I do find /make_tetrahedron()/ function that can be used to add a
new tetrahedron into LCC, but can it assure that these new tetrahedrons are
exactly aligned with the boundary of previously created cavity?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Implementing-tetrahedral-mesh-with-cavities-using-Linear-cell-complex-tp4659399.html
- [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex, Pranav, 06/04/2014
- Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex, Guillaume Damiand, 06/05/2014
