cgal-discuss - Re: [cgal-discuss] hierarchy triangulation with point info
  • To:
  • Subject: Re: [cgal-discuss] hierarchy triangulation with point info
  • Date: Fri, 13 Jun 2014 09:39:59 +0200
On 06/13/2014 05:12 AM, ffmm3 wrote:
I have show the typedef at the in my post, such as:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Projection_traits_xy_3<K> Gt;
typedef CGAL::Triangulation_vertex_base_with_info_2<unsigned, Gt> Vbb;
typedef CGAL::Triangulation_hierarchy_vertex_base_2<Vbb> Vb;
typedef CGAL::Triangulation_face_base_2<Gt> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<Gt,Tds> Dt;
typedef CGAL::Triangulation_hierarchy_2<Dt> Hierarchy_triangulation;
Sorry, the typedefs were only shown on nabble and not on the mail I received.
The insert function you are trying to use is not implemented for
the Triangulation_hierarchy_2 because the spatial sorting is not
needed here.
You can simply do
for (int i=0; i<pts.size(); ++i)
ht.insert(pts[i])->info()=i;
Sebastien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/hierarchy-triangulation-with-point-info-tp4659408p4659438.html
