- To:
- Subject: Re: [cgal-discuss] hierarchy triangulation with point info
- Date: Fri, 06 Jun 2014 13:46:58 +0200
On 06/06/2014 12:14 PM, ffmm3 wrote:
Hi, I am doing hierarchy triangulation with point info (e.g., point color, or
point index, etc.), and have some trouble. According the example given at
http://doc.cgal.org/latest/Triangulation_2/index.html
<http://doc.cgal.org/latest/Triangulation_2/index.html> named /Using an
Iterator Over Pairs/, my code is as following:
The error is:
*error C2664: 'CGAL::Point_3<R_>::Point_3(const CGAL::Origin &)' : cannot
convert parameter 1 from 'std::pair<_Ty1,_Ty2>' to 'const CGAL::Origin &'*
What is the problem? And what is the correct method to do this?
Could you show the typedef you are using?
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/hierarchy-triangulation-with-point-info-tp4659408.html
- [cgal-discuss] hierarchy triangulation with point info, ffmm3, 06/06/2014
- Re: [cgal-discuss] hierarchy triangulation with point info, Sebastien Loriot (GeometryFactory), 06/06/2014
- Re: [cgal-discuss] hierarchy triangulation with point info, ffmm3, 06/13/2014
- Re: [cgal-discuss] hierarchy triangulation with point info, Sebastien Loriot (GeometryFactory), 06/13/2014
- Re: [cgal-discuss] hierarchy triangulation with point info, ffmm3, 06/17/2014
