[cgal-discuss] Bug: Surface_mesh_segmentation/segmentation_via_sdf_values_examples
- To: "" <>
- Subject: [cgal-discuss] Bug: Surface_mesh_segmentation/segmentation_via_sdf_values_examples
- Date: Mon, 16 Jun 2014 15:28:58 +0000
- Accept-language: en-US
- Authentication-results: spf=none (sender IP is ) ;
which operating system, compiler, and hardware you are using;
-- Linux, g++, Intel i7-2640M CPU @ 2.80GHz
information about how CGAL was installed on your system (i.e., which options were used, how the library was built, etc.);
-- Download the source code, make install
any third-party software (such as GMP) that is involved;
--NO.
a description of the problem or bug and a way to reproduce it (such as a small sample program or a sequence of commands);
-- run the examples/Surface_mesh_segmentation/segmentation_via_sdf_values_examples using the data file:
Bug: report "Floating point exception (core dumped)"
The stack trace is below:
do not forget to mention which kernel you are using, and check for potential robustness issues you may have;
in case of run-time crash, please include a stack trace provided by the debugger;
in case of problems with the installation, make sure to include the install.log file.
Best Regards
Guilin Liu
Ph.D. student
Computer Science Department
George Mason University
http://masc.cs.gmu.edu/wiki/GuilinLiu
- [cgal-discuss] Bug: Surface_mesh_segmentation/segmentation_via_sdf_values_examples, , 06/16/2014
- Re: [cgal-discuss] Bug: Surface_mesh_segmentation/segmentation_via_sdf_values_examples, Sebastien Loriot (GeometryFactory), 06/16/2014
