- To:
- Subject: Re: [cgal-discuss] Difference between Manifold and Quasi-manifold
- Date: Mon, 16 Jun 2014 12:56:30 +0200
Le 16/06/2014 09:38, Pranav a écrit :
Could you justify how this figure
<http://doc.cgal.org/latest/Combinatorial_map/index.html#fig__figquasivariete>
(object with vertex /p/) represents a quasi-manifold object?
This is a 3D quasi-manifold because it is a set of 2D quasi manifolds that are glued along faces.
I agree that one can cover all faces and edges of the object incident at
/p/, but does it make it quasi-manifold even if opposite pentagons are
/directly/ connected at a vertex(i.e., /p/) only.
I am a bit confused here.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Difference-between-Manifold-and-Quasi-manifold-tp4659420p4659453.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
smime.p7s
Description: Signature cryptographique S/MIME
- [cgal-discuss] Difference between Manifold and Quasi-manifold, (continued)
- [cgal-discuss] Difference between Manifold and Quasi-manifold, Pranav, 06/09/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, David Canino, 06/09/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, Pranav, 06/11/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, David Canino, 06/11/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, Guillaume Damiand, 06/11/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, Guillaume Damiand, 06/12/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, Jeffrey Bush, 06/15/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, Pranav, 06/16/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, Guillaume Damiand, 06/16/2014
- Re: [cgal-discuss] Difference between Manifold and Quasi-manifold, Jeffrey Bush, 06/16/2014
