cgal-discuss - Re: [cgal-discuss] Intersection on set of darts
  • To:
  • Subject: Re: [cgal-discuss] Intersection on set of darts
  • Date: Mon, 23 Jun 2014 10:50:50 +0200
Le 19/06/2014 10:24, Pranav a écrit :
Given a set of darts associated with a tetrahedron(3-cell) /t/ and a set of
darts representing a polyhedron(in combinatorial map representation) /p/. I
want to determine set of common 2-cells(or faces) between /t/ and /p/.
You means pair of faces of t and p having the same geometry ?
If yes the function sew3_same_facets() defined in the class Linear_cell_complex can be used.
It seems to be a standard /set-intersection/ problem between 2 sets of
darts(i.e., *Set 1*: Darts representing faces of /t/, *Set 2*: Darts
representing faces of /p/).
I would like to know if there is any method already available in CGAL for
solving this problem or should I apply brute-force approach for comparing
all possible pairs of faces(represented by darts) of /p/ and /t/?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Intersection-on-set-of-darts-tp4659464.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
