Re: [cgal-discuss] Determine if a point is interior or exterior to a Polyhedron_3
- To:
- Subject: Re: [cgal-discuss] Determine if a point is interior or exterior to a Polyhedron_3
- Date: Fri, 27 Jun 2014 04:13:02 -0700 (PDT)
ChaoM wrote
> In the CGAL Manaul, a closed Polyhedron must meet some Conditions. As you
> say, firstly limited to convex polyhedrons. Problems which I solved is
> two(or more) polyhedrons(polyhedrons' surface is composed of triangles)
> intersect with each other, so I need to compute one poly's points whether
> inside other polys.
I think you are missing one possible case when one polyhedron has no vertex
/inside/ other polyhedron but still both intersect each other.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Determine-if-a-point-is-interior-or-exterior-to-a-Polyhedron-3-tp4466730p4659488.html
- Re: [cgal-discuss] Determine if a point is interior or exterior to a Polyhedron_3, Pranav, 06/27/2014
- Re: [cgal-discuss] Determine if a point is interior or exterior to a Polyhedron_3, Guillaume Damiand, 06/27/2014
- Re: [cgal-discuss] Determine if a point is interior or exterior to a Polyhedron_3, ChaoM, 06/27/2014
- <Possible follow-up(s)>
