- To:
- Subject: Re: [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values'
- Date: Thu, 10 Jul 2014 11:30:16 +0200
Hi Stevens the problem might come fron the declaration : std::list objects;where the template parameter is missing. The template parameter should be a CGAL::Object. A CGAL::Object has to be casted into a real types (here Vb, Fb, Facet or Edge before being able to call the output operator on it. Regards, Mariette Le 06/07/14 02:43, stevens a écrit :
Hi everybody. I'm trying to make an output for the Alpha Complex Filtration of an initial point cloud I have on a text file but I really can't make the options 'filtration_with_alpha_values' and 'filtration' works. My aim is to generate a text file with the information of "all the faces of the triangulation in increasing order of the alpha value for which they appear in the alpha complex. " I've followed the example Alpha_shapes_3/ex_weighted_alpha_shapes_3.cpp found on CGAL webpage and I've gotten the next code: #include <CGAL/Regular_triangulation_euclidean_traits_3.h> #include <CGAL/Regular_triangulation_3.h> #include <CGAL/Alpha_shape_3.h> #include <list> #include <fstream> #include <cassert> #include <iostream> #include <sstream> #include <string> #include <algorithm> #include <vector> #include <CGAL/Object.h> #include <CGAL/tuple.h> using namespace std; typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Regular_triangulation_euclidean_traits_3<K> Gt; typedef CGAL::Alpha_shape_vertex_base_3<Gt> Vb; typedef CGAL::Alpha_shape_cell_base_3<Gt> Fb; typedef CGAL::Triangulation_data_structure_3<Vb,Fb> Tds; typedef CGAL::Regular_triangulation_3<Gt,Tds> Triangulation_3; typedef CGAL::Alpha_shape_3<Triangulation_3> Alpha_shape_3; typedef Alpha_shape_3::Cell_handle Cell_handle; typedef Alpha_shape_3::Vertex_handle Vertex_handle; typedef Alpha_shape_3::Facet Facet; typedef Alpha_shape_3::Edge Edge; typedef Gt::Weighted_point Weighted_point; typedef Gt::Bare_point Bare_point; typedef Gt::Point_3 Point; typedef Alpha_shape_3::Alpha_iterator Alpha_iterator; typedef Gt::FT FT; typedef CGAL::Object Object; int main(int argc, char* argv[]) { std::list<Weighted_point> lwp; string infile = argv[1]; string outfile = (argc >= 3)? argv[2] : "output"; string eng = (argc >= 4) ? argv[3] : "a"; std::ifstream is; is.open(infile.c_str(), ifstream::in); if (!is.good()) { std::cout<<"\nUnable to Open File "<<infile<<" for reading!"; return -2; } int n; is >> n; std::cout << "Reading " << n << " points " << std::endl; double x, y, z, r; for( ; n>0 ; n--) { //is >> p; is >> x; is >> y; is >> z; is >> r; lwp.push_back(Weighted_point(Bare_point( x, y, z), r)); } is.close(); //build alpha_shape in GENERAL mode and set alpha=0 Alpha_shape_3 as(lwp.begin(), lwp.end(),0, Alpha_shape_3::GENERAL); //explore the 0-shape - It is dual to the boundary of the union. std::list<Cell_handle> cells; std::list<Facet> facets; std::list<Edge> edges; as.get_alpha_shape_cells(std::back_inserter(cells),Alpha_shape_3::INTERIOR); as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::REGULAR); as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::SINGULAR); as.get_alpha_shape_edges(std::back_inserter(edges),Alpha_shape_3::SINGULAR); std::cout << " The 0-shape has : " << std::endl; std::cout << cells.size() << " interior tetrahedra" << std::endl; std::cout << facets.size() << " boundary facets" << std::endl; std::cout << edges.size() << " singular edges" << std::endl; //i'm not sure if this is the correct way to access the filtration std::list objects; as.filtration(std::back_inserter(objects)); std::cout << objects.size() << std::endl; std::list::iterator pos; pos = objects.begin(); while (pos != objects.end()){ cout << *pos << endl; pos++; } It works, but the information I've found in objects is wrong. Thanks so much for all your suggestions. Regards Stevens -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Help-with-filtration-and-filtration-with-alpha-values-tp4659524.html Sent from the cgal-discuss mailing list archive at Nabble.com. -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values', stevens, 07/06/2014
- Re: [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values', Mariette Yvinec, 07/10/2014
- Re: [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values', stevens, 07/10/2014
- Re: [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values', Sebastien Loriot (GeometryFactory), 07/10/2014
- Re: [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values', stevens, 07/12/2014
