cgal-discuss - Re: [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values'
  • To:
  • Subject: Re: [cgal-discuss] Help with 'filtration' and 'filtration_with_alpha_values'
  • Date: Thu, 10 Jul 2014 23:44:53 +0200
The Dispatch_output_iterator is just to get FT and CGAL::Object in different container.
Something like the following should work:
std::vector<CGAL::Object> objects;
std::vector<FT> alphas;
as.filtration_with_alpha_values(
CGAL::dispatch_output<
CGAL::cpp11::tuple<CGAL::Object, FT> >(
std::back_inserter(objects),
std::back_inserter(alphas))
Sebastien.
On 07/10/2014 11:30 AM, Mariette Yvinec wrote:
Hi Stevens
the problem might come fron the declaration :
std::list objects;
where the template parameter is missing.
The template parameter should be a CGAL::Object.
A CGAL::Object has to be casted into a real types (here Vb, Fb, Facet or
Edge
before being able to call the output operator on it.
Regards,
Mariette
Le 06/07/14 02:43, stevens a écrit :
Hi everybody.
I'm trying to make an output for the Alpha Complex Filtration of an initial
point cloud I have on a text file but I really can't make the options
'filtration_with_alpha_values' and 'filtration' works.
My aim is to generate a text file with the information of "all the faces of
the triangulation in increasing order of the alpha value for which they
appear in the alpha complex. "
I've followed the example Alpha_shapes_3/ex_weighted_alpha_shapes_3.cpp
found on CGAL webpage and I've gotten the next code:
#include <CGAL/Regular_triangulation_euclidean_traits_3.h>
#include <CGAL/Regular_triangulation_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <list>
#include <fstream>
#include <cassert>
#include <iostream>
#include <sstream>
#include <string>
#include <algorithm>
#include <vector>
#include <CGAL/Object.h>
#include <CGAL/tuple.h>
using namespace std;
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Regular_triangulation_euclidean_traits_3<K> Gt;
typedef CGAL::Alpha_shape_vertex_base_3<Gt> Vb;
typedef CGAL::Alpha_shape_cell_base_3<Gt> Fb;
typedef CGAL::Triangulation_data_structure_3<Vb,Fb> Tds;
typedef CGAL::Regular_triangulation_3<Gt,Tds> Triangulation_3;
typedef CGAL::Alpha_shape_3<Triangulation_3> Alpha_shape_3;
typedef Alpha_shape_3::Cell_handle Cell_handle;
typedef Alpha_shape_3::Vertex_handle Vertex_handle;
typedef Alpha_shape_3::Facet Facet;
typedef Alpha_shape_3::Edge Edge;
typedef Gt::Weighted_point Weighted_point;
typedef Gt::Bare_point Bare_point;
typedef Gt::Point_3 Point;
typedef Alpha_shape_3::Alpha_iterator Alpha_iterator;
typedef Gt::FT FT;
typedef CGAL::Object Object;
int main(int argc, char* argv[])
std::list<Weighted_point> lwp;
string infile = argv[1];
string outfile = (argc >= 3)? argv[2] : "output";
string eng = (argc >= 4) ? argv[3] : "a";
std::ifstream is;
is.open(infile.c_str(), ifstream::in);
if (!is.good())
std::cout<<"\nUnable to Open File "<<infile&lt;&lt;&quot; for
reading!&quot;;
return -2;
int n;
is >> n;
std::cout << "Reading " << n << " points " << std::endl;
double x, y, z, r;
for( ; n>0 ; n--) {
//is >> p;
is >> x;
is >> y;
is >> z;
is >> r;
lwp.push_back(Weighted_point(Bare_point( x, y, z), r));
is.close();
//build alpha_shape in GENERAL mode and set alpha=0
Alpha_shape_3 as(lwp.begin(), lwp.end(),0, Alpha_shape_3::GENERAL);
//explore the 0-shape - It is dual to the boundary of the union.
std::list<Cell_handle> cells;
std::list<Facet> facets;
std::list<Edge> edges;
as.get_alpha_shape_cells(std::back_inserter(cells),Alpha_shape_3::INTERIOR);
as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::REGULAR);
as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::SINGULAR);
as.get_alpha_shape_edges(std::back_inserter(edges),Alpha_shape_3::SINGULAR);
std::cout << " The 0-shape has : " << std::endl;
std::cout << cells.size() << " interior tetrahedra" << std::endl;
std::cout << facets.size() << " boundary facets" << std::endl;
std::cout << edges.size() << " singular edges" << std::endl;
//i'm not sure if this is the correct way to access the filtration
std::list objects;
as.filtration(std::back_inserter(objects));
std::cout << objects.size() << std::endl;
std::list::iterator pos;
pos = objects.begin();
while (pos != objects.end()){
cout << *pos << endl;
pos++;
It works, but the information I've found in objects is wrong.
Thanks so much for all your suggestions.
Regards
Stevens
View this message in
context:http://cgal-discuss.949826.n4.nabble.com/Help-with-filtration-and-filtration-with-alpha-values-tp4659524.html
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
