Re: [cgal-discuss] A Simple question about typedef Gps_trait_2::Polygon_with_holes_2
- To:
- Subject: Re: [cgal-discuss] A Simple question about typedef Gps_trait_2::Polygon_with_holes_2
- Date: Sun, 13 Jul 2014 10:38:57 +0300
You cannot compile
approximated_offset_2(p, r, eps)
where the p is defined as Polygon_with_holes_2 (even if p actually doesn't have holes).approximated_offset_2(p, r, eps)
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Thu, Jul 10, 2014 at 12:05 PM, BenChen <> wrote:
Hi,
My input polygon doesn't have holes. However, I want to get the coordinate
of resulted polygon's vertices. How can I get them from the result of this
function
View this message in context: http://cgal-discuss.949826.n4.nabble.com/A-Simple-question-about-typedef-Gps-trait-2-Polygon-with-holes-2-tp4659530p4659544.html
- [cgal-discuss] A Simple question about typedef Gps_trait_2::Polygon_with_holes_2, BenChen, 07/07/2014
- Re: [cgal-discuss] A Simple question about typedef Gps_trait_2::Polygon_with_holes_2, Efi Fogel, 07/09/2014
- Re: [cgal-discuss] A Simple question about typedef Gps_trait_2::Polygon_with_holes_2, BenChen, 07/10/2014
- Re: [cgal-discuss] A Simple question about typedef Gps_trait_2::Polygon_with_holes_2, Efi Fogel, 07/13/2014
