- To:
- Subject: Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3
- Date: Wed, 23 Jul 2014 20:52:33 -0700 (PDT)
I have met an identical problem as you. I can't open the website you refferd,
namely
"I google it and have found the following existing topics:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2007-11/msg00028.html
and Alvaro has uploaded his solution:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2007-12/msg00053.html"
What was the solution and how did you solve it finally?
Thank you!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/On-rendering-of-Polyhedron-in-CGAL-3-3-tp2714204p4659601.html
- Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3, sean, 07/24/2014
- Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3, kyewong, 07/24/2014
