- To:
- Subject: Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3
- Date: Thu, 24 Jul 2014 07:13:59 -0700 (PDT)
Hello, Wang Kai, if you are Chinese too.
Thank you for helping.
I will make a try. And if I meet difficulties,
I want to discuss them with you if you don't mind.
Sean
2014-07-24
Date: 2014-07-24 21:33
To: [hidden email]
Subject: Re: On rendering of Polyhedron in CGAL
3.3
Hi sean, I solved it by using the opengl
list functions, including
glgenlist... u can easily find how to use it on google
On 7/24/14, sean [via cgal-discuss]
<[hidden email]> wrote:
> I have met an identical problem as you. I can't open the website you
> refferd,
> namely
> "I google it and have found the following existing topics:
> https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2007-11/msg00028.html
> and Alvaro has uploaded his solution:
> https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2007-12/msg00053.html"
> What was the solution and how did you solve it finally?
> Thank you!
> _______________________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://cgal-discuss.949826.n4.nabble.com/On-rendering-of-Polyhedron-in-CGAL-3-3-tp2714204p4659601.html
> To unsubscribe from On rendering of Polyhedron in CGAL 3.3, visit
>Kai WANG
To
unsubscribe from On rendering of Polyhedron in CGAL 3.3, click
here.
NAML
> refferd,
> namely
> Thank you!
> below:
added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/On-rendering-of-Polyhedron-in-CGAL-3-3-tp2714204p4659607.html
NAML
View this message in context: Re: Re: On rendering of Polyhedron in CGAL 3.3
- Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3, sean, 07/24/2014
- Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3, kyewong, 07/24/2014
