- To:
- Subject: Re: [cgal-discuss] Closest distance + vertices of two meshes
- Date: Mon, 28 Jul 2014 14:04:19 +0200
Thanks for the link Giles!
It is interesting, following a different approach than what I was expecting, but I'm afraid it's not exactly what I need.I would really need the id's of the vertices (or triangles), not just the distance.
If I'm not mistaken this method finds the distance between the two convex hulls, without really finding the hulls.
So in the end of the day vertex-IDs are probably still missing.
I think that CGAL::all_furthest_neighbors_2 does kind of what I need, but in the opposite way.
Any other thought or hint on this problem would be highly appreciated.
On Mon, Jul 28, 2014 at 12:27 PM, Giles Bathgate <> wrote:
Is this what you are looking for?
http://doc.cgal.org/latest/Polytope_distance_d/group__PkgOptimalDistances.html
On 28 July 2014 11:19, Dimitris Tzionas <> wrote:
> Hi all,
> I would like to find two vertices of two meshes (1 vertex per mesh) that
> define the closest distance between them. Or the two triangles would be fine
> I guess.
> However I'm not sure how to search for this in CGAL's documentation, I'm
> sure that this is doable with some existing tool (probably based on a 3d
> distance field and/or AABBs). Could I please get a hint (keywords/link) on
> what to look for?
> I've already implemented a collision detection with CGAL to find the
> triangle-triangle intersection in a triangle-soup, using AABB-trees. I guess
> that I should be somehow close to this, although now a simple soup with all
> me object-triangles wouldn't do the job.
> Best,
> dimitris
- [cgal-discuss] Closest distance + vertices of two meshes, Dimitris Tzionas, 07/28/2014
- Re: [cgal-discuss] Closest distance + vertices of two meshes, Giles Bathgate, 07/28/2014
- Re: [cgal-discuss] Closest distance + vertices of two meshes, Dimitris Tzionas, 07/28/2014
- Re: [cgal-discuss] Closest distance + vertices of two meshes, Dimitris Tzionas, 07/29/2014
- Re: [cgal-discuss] Closest distance + vertices of two meshes, Jeffrey Bush, 07/29/2014
