cgal-discuss - Re: [cgal-discuss] Intersection between a ray and a cell
  • To:
  • Subject: Re: [cgal-discuss] Intersection between a ray and a cell
  • Date: Mon, 28 Jul 2014 14:05:42 +0200
On 07/28/2014 01:01 PM, Cedric Doucet wrote:
Thank you very much!
I am sorry I have a last question about intersection.
Return types are defined in a table at
http://doc.cgal.org/latest/Kernel_23/group__intersection__linear__grp.html.
But what is the return type when two objects do not intersect?
How can we test if two objects intersect from the return type?
return type is a boost::optional< boost:variant<..> > which can be evaluated to bool.
Sebastien.
Cédric
----- Mail original -----
De: "Sebastien Loriot (GeometryFactory)"
À:
Envoyé: Lundi 28 Juillet 2014 11:52:13
Objet: Re: [cgal-discuss] Intersection between a ray and a cell
On 07/28/2014 11:50 AM, Cedric Doucet wrote:
Good! That's the case for me!
Is there a CGAL function which returns the opposite facet to a given vertex
in a cell?
cell->index(v) gives you the index of the vertex_handle v in cell.
Sebastien.
Have a good day,
Cédric
À:
Envoyé: Lundi 28 Juillet 2014 11:35:01
On 07/28/2014 11:30 AM, cdoucet wrote:
Thank you, that's a good idea!
Do you think it will work even in special cases, such as as when the ray
lies inside a facet shared by two of incident cells to q?
If you have exact predicates yes, the ray go through the edge shared by
two facets.
Sebastien.
Best,
Cédric
*De: *"Sebastien Loriot (GeometryFactory) [via cgal-discuss]"
<[hidden email] </user/SendEmail.jtp?type=node&node=4659624&i=0>>
*À: *"cdoucet" <[hidden email]
</user/SendEmail.jtp?type=node&node=4659624&i=1>>
*Envoyé: *Lundi 28 Juillet 2014 11:26:01
*Objet: *Re: Intersection between a ray and a cell
I think for each cell you only need to consider the triangle facet
that
is opposite to q in all your intersection queries.
Sebastien.
On 07/28/2014 11:17 AM, Cedric Doucet wrote:
> Hello Sébastien,
> thank you very much for your answer.
> My problem is the following: given two points p and q, find the
cells which are
> 1. incident to q,
> 2. intersected by ray (p,q)
> 3. NOT intersected by segment [p,q].
> I do not exactly how to do that efficiently.
> My (naive) algorithm is the following:
> 1. create a ray (p,q) and find cells incident to q which are
intersected by (p,q)
> 2. create a segment [p,q] and find cells incident to q which are
intersected by [p,q]
> 3. compute the topological intersection of sets from 1 and 2.
> I managed to find cells which are incident to q using
incident_cells function from CGAL.
> I also managed to construct a ray and a segment from p and q.
> I now have to find which cells are intersected by (p,q) and not
[p,q].
> My naive algorithm consist in
> 1. intersectedCells = std::vector(number of incident cells to q);
> 2. for each incidentCellToQ do
> 3. for vertexIndex = 0 to 3 do
> 4. Triangle t = triangle(incidentCellToQ,vertexIndex);
> 5. if intersection(segment,t).empty() do
> 6. if ! intersection(segment,t).empty() do
> 7. intersectedCells.pushback(incidentCellToQ)
> 8. end if
> 9. end if
> 10. end for
> 11. end for
> The above algorithm is not very well written (and maybe false)
because I have not finished to implement it and test it.
> However, I feel that I will compute to many things.
> Having a function to compute intersection between a ray and a
cell could be useful here.
> Do you think there exist a more simple solution in CGAL?
> Best,
> Cédric
>> De: "Sebastien Loriot (GeometryFactory)" <[hidden email]
</user/SendEmail.jtp?type=node&node=4659623&i=0>>
>> À: [hidden email]
>> </user/SendEmail.jtp?type=node&node=4659623&i=1>
>> Envoyé: Lundi 28 Juillet 2014 10:42:27
>> It's not clear to me what you are looking for (what you say
about nodes
>> confuses me).
>> Is the ray arbitrary and do you want to know all the finite
>> cells
>> intersected by that ray?
>> Sebastien.
>> On 07/28/2014 10:22 AM, cdoucet wrote:
>>> Hello,
>>> In a 3D Delaunay triangulation, I would like to know which
tetraedra
>>> (indicent to the same node) are intersected by a given ray
(passing through
>>> this node).
>>> I found in the documentation that intersections between rays
and other
>>> cells
>>> can be computed:
>>> However, it does not seem possible to call intersection
function for a ray
>>> and a tetrahedron (or a Cell_handle).
>>> How could I perform such an intersection with CGAL?
>>> Thank you very much for your help.
>>> Cédric Doucet
>>> Inria Paris-Rocquencourt
>>> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Intersection-between-a-ray-and-a-cell-tp4659619.html
>>> Sent from the cgal-discuss mailing list archive at Nabble.com.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://sympa.inria.fr/sympa/info/cgal-discuss
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Intersection-between-a-ray-and-a-cell-tp4659619p4659623.html
To unsubscribe from Intersection between a ray and a cell, click
here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: Intersection between a ray and a cell
<http://cgal-discuss.949826.n4.nabble.com/Intersection-between-a-ray-and-a-cell-tp4659619p4659624.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
