[cgal-discuss] Empty lines with output stream operator overloading for 3D triangulations
- To:
- Subject: [cgal-discuss] Empty lines with output stream operator overloading for 3D triangulations
- Date: Tue, 29 Jul 2014 03:52:40 -0700 (PDT)
Hello,
I used 3D Delaunay triangulations with the following definitions:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_with_info_3<int, K> Vb;
typedef CGAL::Triangulation_cell_base_with_info_3<CellInfo, K> Cb;
typedef CGAL::Triangulation_data_structure_3<Vb,Cb> Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds>
Delaunay;
In my code, I generate such a triangulation T and try to write it in a file
std::ofstream ofs;
ofs.open(file,std::ios::out);
CGAL::set_ascii_mode(ofs);
ofs << T;
where file if of type (char*).
When I open the resulting file, data seem to be written correctly but they
are followed by several empty lines (about 60,000).
Is this normal?
Thank you for your help!
Cédric Doucet
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Empty-lines-with-output-stream-operator-overloading-for-3D-triangulations-tp4659644.html
- [cgal-discuss] Empty lines with output stream operator overloading for 3D triangulations, cdoucet, 07/29/2014
- Re: [cgal-discuss] Empty lines with output stream operator overloading for 3D triangulations, Cedric Doucet, 07/29/2014
