- To:
- Subject: Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations
- Date: Wed, 30 Jul 2014 14:04:06 -0600
There are no removal or insertions, only vertex value modifications.
On Wed, Jul 30, 2014 at 2:00 PM, Sebastien Loriot (GeometryFactory) <> wrote:
On 07/30/2014 07:00 PM, Sylvain Pion wrote:To be more precise, if you do some removal in T1, then create T2
I'm not sure why you fear something related to the removal.
and insert elements both in T1 and T2 even in the same order then
the order of faces will be different.
Sebastien.
< <mailto:>>:
As far as safety, it might well be OK now, but as long as it's not a
documented guarantee, who knows what can happen in future releases...
2014-07-30 0:08 GMT-07:00 Sebastien Loriot (GeometryFactory)http://cgal-discuss.949826.n4.__nabble.com/Simultaneous-__iteration-over-duplicate-__triangulations-__tp4659640p4659655.html
On 07/30/2014 12:32 AM, chrism wrote:
Is this an undocumented determinism that is likely to break in a
future
release? Or can I depend upon this?
Faces are stored in a container so the copy will produce the same
container (if no removal is done, or at least more vertices were added
after the removal).
I think it is safe to depend upon this.
Sebastien.
View this message in context:https://sympa.inria.fr/sympa/__info/cgal-discuss
<http://cgal-discuss.949826.n4.nabble.com/Simultaneous-iteration-over-duplicate-triangulations-tp4659640p4659655.html>
<https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] Simultaneous iteration over duplicate triangulations, chrism, 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Sebastien Loriot (GeometryFactory), 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Chris Marsh, 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Olivier Devillers, 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, chrism, 07/30/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Sebastien Loriot (GeometryFactory), 07/30/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Chris Marsh, 07/30/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Sylvain Pion, 07/30/2014
