- To:
- Subject: Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations
- Date: Tue, 29 Jul 2014 21:31:12 +0200
On 07/29/2014 08:56 AM, Olivier Devillers wrote:
Le 29/07/14 04:58, chrism a écrit :
Hi all, my past two questions ended up being me missing documentation,yes, there is no guarantee.
so I
apologize in advance if this is the case here. However, I don't think
it is.
Suppose I have a triangulation T1, and I create a copy of it in T2 (so T1
and T2 are equal in every way). Then, I want to iterate over the faces
of T1
and T2 simultaneously with iterators t1 and t2. However, I want the
constraint that t1 and t2 point to the 'same' face in T1 and T2.
This would be analogous to traversing two duplicated vectors, where
v[0] ==
v2[0].
From what I understand, finite_face_iterator makes no guarantees
about the
determinism of: a) the starting face or b) traversal order.
You may enrich your triangulation faces to be able to put cross pointers
between the faces of the two triangulations.
Note that if you are not doing any vertex removal I think it should be
deterministic in 2D.
Sebastien.
- [cgal-discuss] Simultaneous iteration over duplicate triangulations, chrism, 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Sebastien Loriot (GeometryFactory), 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Chris Marsh, 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Olivier Devillers, 07/29/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, chrism, 07/30/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Sebastien Loriot (GeometryFactory), 07/30/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Chris Marsh, 07/30/2014
- Re: [cgal-discuss] Simultaneous iteration over duplicate triangulations, Sylvain Pion, 07/30/2014
