- To:
- Subject: Re: [cgal-discuss] "This compiler does not have a working STL" error
- Date: Mon, 18 Aug 2014 13:47:47 +0200
Le Saturday 16 August 2014 20:59:11 jeffwang a écrit :
> And here is the output of a seemingly successful CGAL configuring process.
> jeffwang@ubuntu:~/CGAL-3.9$ cmake -G"Unix Makefiles"
> -- Build CGAL from release: CGAL-3.9
Please remove $HOME/CGAL-3.9/CMakeCache.txt, restart that command, store
somewhere the full log of that run of CMake. Then retry to build the CGAL
libraries, and if that fails again, please give us the full cmake log
(obtained from the first run from a cleared cache), and the compilation log.
Laurent Rineau, PhD
- [cgal-discuss] "This compiler does not have a working STL" error, jeffwang, 08/17/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Laurent Rineau (CGAL/GeometryFactory), 08/18/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, jeffwang, 08/20/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Joachim Reichel, 08/20/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Joachim Reichel, 08/22/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, jeffwang, 08/23/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Joachim Reichel, 08/24/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Laurent Rineau (CGAL/GeometryFactory), 08/20/2014
