- To:
- Subject: Re: [cgal-discuss] "This compiler does not have a working STL" error
- Date: Wed, 20 Aug 2014 04:05:50 -0700 (PDT)
2014-08-18 16:58:04 status installed libcgal-dev 3.9-1build1
2014-08-18 16:58:04 trigproc libc-bin 2.15-0ubuntu10.6 <none>
2014-08-18 16:58:04 status half-configured libc-bin 2.15-0ubuntu10.6
2014-08-18 16:58:04 status installed libc-bin 2.15-0ubuntu10.6
2014-08-18 16:58:54 startup archives unpack
2014-08-18 16:58:54 install libxmlrpc-core-c3 <none> 1.16.33-3.1ubuntu5.1
2014-08-18 16:58:54 status half-installed libxmlrpc-core-c3
2014-08-18 16:58:54 status unpacked libxmlrpc-core-c3 1.16.33-3.1ubuntu5.1
2014-08-18 16:58:54 install cmake-data <none> 2.8.7-0ubuntu5
Hi Joachim,
I look through the /var/log/dpkg.log you mentioned. I guess the above is
what happened after libcgal-dev installed and before cmake installation. I
am not quite sure, though, unless I do it again from scratch.
Jeffrey
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/This-compiler-does-not-have-a-working-STL-error-tp4659704p4659719.html
- [cgal-discuss] "This compiler does not have a working STL" error, jeffwang, 08/17/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Laurent Rineau (CGAL/GeometryFactory), 08/18/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, jeffwang, 08/20/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Joachim Reichel, 08/20/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Joachim Reichel, 08/22/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, jeffwang, 08/23/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Joachim Reichel, 08/24/2014
- Re: [cgal-discuss] "This compiler does not have a working STL" error, Laurent Rineau (CGAL/GeometryFactory), 08/20/2014
