- To: cgal-discuss <>
- Subject: [cgal-discuss] CGAL 4.5 beta1: Problems meshing off file
- Date: Tue, 2 Sep 2014 03:06:42 +0200
Hello CGAL people!
I have been running the test suite of my mesh generation tool for
FEniCS with CGAL 4.5-beta1 and I get one error:
When trying to mesh the demo/Polyhedron/data/rotor.off with the
attached program I get the following error message
benjamik@benjamik-ThinkPad-X300:~/tmp/cgal-meshing/build$ ./main
~/software/CGAL-4.5-beta1/demo/Polyhedron/data/rotor.off
Inserting protection balls...
refine_balls = true
min_balls_radius = 0
min_balls_weight = 0
insert_corners() done. Nb of points in triangulation: 4
insert_balls_on_edges() done. Nb of points in triangulation: 350
refine_balls() done. Nb of points in triangulation: 784
Point p[0.225806 0.421836 0.0134309], dim=1 and q[0.225806 0.419777
0.0312588], dim=1 form an edge but do not intersect !
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: minimal_size_ > 0 || c3t3_.is_valid()
File:
/home/benjamik/software/cgal-4.5-install/include/CGAL/Mesh_3/Protect_edges_sizing_field.h
Line: 370
Aborted (core dumped)
This is with a debug build of CGAL 4.5 beta1 on 32 bit Ubuntu 14.04
with gcc 4.8.2
Regards
Benjamin Kehlet
#define CGAL_NO_DEPRECATED_CODE #define CGAL_MESH_3_VERBOSE #define CGAL_MESH_3_NO_DEPRECATED_SURFACE_INDEX #define CGAL_MESH_3_NO_DEPRECATED_C3T3_ITERATORS #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Mesh_triangulation_3.h> #include <CGAL/Mesh_complex_3_in_triangulation_3.h> #include <CGAL/Mesh_criteria_3.h> #include <CGAL/Polyhedral_mesh_domain_with_features_3.h> #include <CGAL/make_mesh_3.h> // Domain typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Polyhedral_mesh_domain_with_features_3<K> Mesh_domain; typedef CGAL::Mesh_polyhedron_3<K>::type MeshPolyhedron_3; // Triangulation typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr; typedef CGAL::Mesh_complex_3_in_triangulation_3< Tr,Mesh_domain::Corner_index,Mesh_domain::Curve_segment_index> C3t3; // Criteria typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria; // To avoid verbose function and named parameters call using namespace CGAL::parameters; int main(int argc, char** argv) { // CGAL::default_random = CGAL::Random( atoi(argv[1]) ); MeshPolyhedron_3 P; { std::ifstream infile(argv[1]); infile >> P; } CGAL_assertion(P.is_pure_triangle()); // Create domain Mesh_domain domain(P); // Get sharp features domain.detect_features(); const double cs = 0.071684; // Mesh criteria Mesh_criteria criteria(edge_size = cs, facet_angle = 30, facet_size = cs, facet_distance = cs/10.0, cell_radius_edge_ratio = 3, cell_size = cs); // Mesh generation C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, CGAL::parameters::no_perturb(), CGAL::parameters::no_exude()); }
- [cgal-discuss] CGAL 4.5 beta1: Problems meshing off file, Benjamin Kehlet, 09/02/2014
