Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices
- To:
- Subject: Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices
- Date: Mon, 1 Sep 2014 09:23:17 -0700 (PDT)
A simpler question, is there a way to get CGAL to merge vertices to a given
tolerance prior to extracting the data?
Sebastien Loriot (GeometryFactory) wrote
> What kernel are you using internally to do the computation?
> I guess you export the result into double/float which result in rounding
> of the exact output, which result in points having the same coordinates
> in your case.
> Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-difference-on-Nef-polyhedron-produces-shape-with-duplicate-vertices-tp4659760p4659764.html
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/01/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, crobar, 09/01/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/04/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, crobar, 09/04/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/10/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, crobar, 09/15/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/22/2014
