- To:
- Subject: Re: [cgal-discuss] Nearest neighbourhood incremental search
- Date: Thu, 04 Sep 2014 08:34:55 +0200
On 08/29/2014 01:14 AM, David Scriven wrote:
Given a set, D, of (x, y, z) triplets in Euclidean 3 space, I wantFirst, points are duplicated inside the search structure so you'll need to create a new search structure.
identify groups K1..n that have the following simple characteristic:
For every tj that is a member of Ki there exists a tm (m != j) s.t.
Euclidean dist(tj, tm) < value.
Looking through CGAL it seemed that the NN incremental search would help
me identify these groups and I modified the example given:
int valsq = value*value;
// A functor that returns true, iff the distance of a 3D point is
greater than value^2
struct X_gt_valsq {
bool operator()(const NN_iterator& it) { return ((*it).second > valsq); }
typedef CGAL::Filter_iterator<NN_iterator, X_gt_valsq> NN_gtvalsq_iterator;
std::list<Point_3> coords;
......// add points.....
Tree tree(coords.begin(), coords.end());
Point_3 query(x,y,z); // some member of coords
NN_incremental_search NN(tree, query);
NN_gtvalsq_iterator it(NN.end(), X_gt_valsq(), NN.begin()),
end(NN.end(), X_gt_valsq());
while(it!=end)
std::cout << (*it).first << " at squared distance = " <<
(*it).second << std::endl;
it++;
which works, but I can't see how to use the information from the
iterator it (which is an input_iterator) to identify which members of
coords are with a NN distance of < valsq so that I can delete them from
the coords dataset to start the next search. Any advice?
If you want to relate to the original points, you can use for example an integer as point type in the search structure. like in this example:
http://doc.cgal.org/latest/Spatial_searching/index.html#title11
Sebastien.
- Re: [cgal-discuss] Nearest neighbourhood incremental search, Sebastien Loriot (GeometryFactory), 09/04/2014
