- To:
- Subject: Re: [cgal-discuss] Not able to configure and build
- Date: Thu, 04 Sep 2014 09:40:35 +0200
On 09/04/2014 09:05 AM,
wrote:
<quote author='Sebastien Loriot (GeometryFactory)'>Could you post your CMakeCache?
On 09/03/2014 06:29 PM, ramesh wrote:
Hi all,
I am new to CGAL. Recently I installed CGAL from the installation page
http://doc.cgal.org/latest/Manual/installation.html .
When I try to configure and build Triangulation_2 under demo folder, I get
the following.
super@Jallu:~/Downloads/CGAL-4.4/demo/Triangulation_2$ cmake .
-- Build type: Release
-- USING CXXFLAGS = '-g -O2 -fstack-protector --param=ssp-buffer-size=4
-Wformat -Wformat-security -frounding-math -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -Wl,-Bsymbolic-functions -Wl,-z,relro '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- NOTICE: This demo requires CGAL and Qt4, and will not be compiled.
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/super/Downloads/CGAL-4.4/demo/Triangulation_2
It says QT4 is required, but I already installed it. Please help to solve
this problem. I would be grateful to you.
echo $CGAL_DIR?
Was libCGAL_QT4 compiled successfully when building CGAL?
Sebastien.
Hi Sebastien
1) /usr/lib/CGAL
2) libCGAL_QT4 was compiled successfully.
I am not getting where it went wrong. I am confused and fed up with it.
Please help me.
_____________________________________
Sent from http://cgal-discuss.949826.n4.nabble.com
- [cgal-discuss] Not able to configure and build, ramesh, 09/03/2014
- Re: [cgal-discuss] Not able to configure and build, chrism, 09/03/2014
- Re: [cgal-discuss] Not able to configure and build, ramesh, 09/03/2014
- Re: [cgal-discuss] Not able to configure and build, ramesh, 09/04/2014
- Re: [cgal-discuss] Not able to configure and build, Sebastien Loriot (GeometryFactory), 09/04/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] Not able to configure and build, Sebastien Loriot (GeometryFactory), 09/05/2014
- Re: [cgal-discuss] Not able to configure and build, ramesh, 09/05/2014
