Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices
- To:
- Subject: Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices
- Date: Thu, 4 Sep 2014 08:15:49 -0700 (PDT)
Sebastien Loriot (GeometryFactory) wrote
> You can try using the Surface mesh simplification package and remove
> short edges:
> http://doc.cgal.org/latest/Surface_mesh_simplification/index.html
> Sebastien.
I've had a go using this, but I'm not getting the results I'm expecting, or
rather I'm failing to prune the short edges. Here is what I tried (largely
based on the example shown in
http://doc.cgal.org/latest/Surface_mesh_simplification/Surface_mesh_simplification_2edge_collapse_enriched_polyhedron_8cpp-example.html
#include <CGAL/Polyhedron_items_with_id_3.h>
#include<CGAL/Nef_polyhedron_3.h>
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include<CGAL/Polyhedron_incremental_builder_3.h>
#include<CGAL/Polyhedron_3.h>
#include<CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Iterator_project.h>
#include <CGAL/function_objects.h>
// Adaptor for Polyhedron_3
#include <CGAL/Surface_mesh_simplification/HalfedgeGraph_Polyhedron_3.h>
// Simplification function
#include <CGAL/Surface_mesh_simplification/edge_collapse.h>
// Visitor base
#include <CGAL/Surface_mesh_simplification/Edge_collapse_visitor_base.h>
// Stop-condition policy
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Count_ratio_stop_predicate.h>
// Non-default cost and placement policies
#include <CGAL/Surface_mesh_simplification/Detail/Common.h>
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Midpoint_and_length.h>
//#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/LindstromTurk_placement.h>
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Edge_profile.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
// the following is used for checking for degenerate meshes
typedef Kernel::Point_3 Point ;
typedef CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>
Polyhedron_id;
typedef Polyhedron_id::Halfedge_handle Halfedge_handle ;
typedef Polyhedron_id::Vertex_handle Vertex_handle ;
typedef CGAL::Surface_mesh_simplification::Edge_profile<Polyhedron_id>
Profile ;
typedef boost::graph_traits<Polyhedron_id>::edges_size_type size_type ;
// -= stopping condition predicate =-
// Determines whether the simplification has finished.
// The arguments are
(current_cost,vertex,vertex,is_edge,initial_pair_count,current_pair_count,surface)
and the result is bool
// Stops when the cost is below some tolerance
template<class ECM_>
class length_stop_predicate
public:
typedef ECM_ ECM ;
typedef CGAL::Surface_mesh_simplification::Edge_profile<ECM>
Profile ;
typedef typename boost::graph_traits<ECM>::edge_descriptor
edge_descriptor ;
typedef typename boost::graph_traits<ECM>::edges_size_type
size_type ;
typedef typename CGAL::halfedge_graph_traits<ECM>::Point Point ;
typedef typename CGAL::Kernel_traits<Point>::Kernel Kernel ;
typedef typename Kernel::FT FT ;
public :
length_stop_predicate( double tolerance ) : _tol(tolerance) {}
bool operator()( FT const& aCurrentCost // aCurrentCost
, Profile const& //aEdgeProfile
, size_type //aInitialCount
, size_type //aCurrentCount
) const
std::cout << "sqrt aCurrentCost Is " <<
sqrt(CGAL::to_double(aCurrentCost)) << " _tol is " << _tol << std::endl;
return ( sqrt(CGAL::to_double(aCurrentCost)) > _tol );
private:
double _tol;
// The following is a Visitor that keeps track of the simplification
process.
// In this example the progress is printed real-time and a few statistics
are
// recorded (and printed in the end).
struct Stats
Stats()
: collected(0)
, processed(0)
, collapsed(0)
, non_collapsable(0)
, cost_uncomputable(0)
, placement_uncomputable(0)
std::size_t collected ;
std::size_t processed ;
std::size_t collapsed ;
std::size_t non_collapsable ;
std::size_t cost_uncomputable ;
std::size_t placement_uncomputable ;
struct My_visitor :
CGAL::Surface_mesh_simplification::Edge_collapse_visitor_base<Polyhedron_id>
My_visitor( Stats* s) : stats(s){}
// Called during the collecting phase for each edge collected.
void OnCollected( Profile const&, boost::optional<Kernel::FT> const& )
++ stats->collected ;
std::cerr << "Edges collected: " << stats->collected << std::endl
<< std::flush ;
// Called during the processing phase for each edge selected.
// If cost is absent the edge won't be collapsed.
void OnSelected(Profile const&
,boost::optional<Kernel::FT> cost
,std::size_t initial
,std::size_t current
++ stats->processed ;
if ( !cost )
++ stats->cost_uncomputable ;
if ( current == initial )
std::cerr << "\n" << std::flush ;
std::cerr << "\r" << current << std::flush ;
// Called during the processing phase for each edge being collapsed.
// If placement is absent the edge is left uncollapsed.
void OnCollapsing(Profile const&
,boost::optional<Point> placement
if ( !placement )
++ stats->placement_uncomputable ;
// Called for each edge which failed the so called link-condition,
// that is, which cannot be collapsed because doing so would
// turn the surface mesh into a non-manifold.
void OnNonCollapsable( Profile const& )
++ stats->non_collapsable;
// Called AFTER each edge has been collapsed
void OnCollapsed( Profile const&, Vertex_handle )
++ stats->collapsed;
Stats* stats ;
Then, where I convert from CGAL to my own polyhedron construct, I first do
the mesh simplification like so:
polyhedron cgal_to_polyhedron( const Nef_polyhedron &NP ){
Polyhedron_id P;
polyhedron ret;
if( NP.is_simple() )
NP.convert_to_polyhedron(P);
// ensure there are no degenerate (too small) edges
// The items in this polyhedron have an "id()" field
// which the default index maps used in the algorithm
// need to get the index of a vertex/edge.
// However, the Polyhedron_3 class doesn't assign any value to
// this id(), so we must do it here:
int index = 0 ;
for( Polyhedron_id::Halfedge_iterator eb = P.halfedges_begin()
, ee = P.halfedges_end()
; eb != ee
; ++ eb
eb->id() = index++;
index = 0 ;
for( Polyhedron_id::Vertex_iterator vb = P.vertices_begin()
, ve = P.vertices_end()
; vb != ve
; ++ vb
vb->id() = index++;
length_stop_predicate<Polyhedron_id> stop (0.001);
//CGAL::Surface_mesh_simplification::Count_ratio_stop_predicate<Polyhedron_id>
stop(0.99);
Stats stats ;
My_visitor vis(&stats) ;
// The index maps are not explicitetly passed as in the previous
// example because the surface mesh items have a proper id() field.
// On the other hand, we pass here explicit cost and placement
// function which differ from the default policies, ommited in
// the previous example.
int r = CGAL::Surface_mesh_simplification::edge_collapse (
P
,stop
,CGAL::get_cost
(CGAL::Surface_mesh_simplification::Edge_length_cost <Polyhedron_id>())
.get_placement(CGAL::Surface_mesh_simplification::LindstromTurk_placement<Polyhedron_id>())
.visitor (vis)
std::cout << "\nEdges collected: " << stats.collected
<< "\nEdges processed: " << stats.processed
<< "\nEdges collapsed: " << stats.collapsed
<< std::endl
<< "\nEdges not collapsed due to topological constriants:
" << stats.non_collapsable
<< "\nEdge not collapsed due to cost computation
constriants: " << stats.cost_uncomputable
<< "\nEdge not collapsed due to placement computation
constriants: " << stats.placement_uncomputable
<< std::endl ;
std::cout << "\nFinished...\n" << r << " edges removed.\n"
<< (P.size_of_halfedges()/2) << " final edges.\n" ;
std::vector<double> coords;
std::vector<int> tris;
int next_id = 0;
std::map< Polyhedron_id::Vertex*, int > vid;
for( Polyhedron_id::Vertex_iterator iter = P.vertices_begin(); iter
!= P.vertices_end(); iter++ )
coords.push_back( CGAL::to_double( (*iter).point().x() ) );
coords.push_back( CGAL::to_double( (*iter).point().y() ) );
coords.push_back( CGAL::to_double( (*iter).point().z() ) );
vid[ &(*iter) ] = next_id++;
for( Polyhedron_id::Facet_iterator iter = P.facets_begin(); iter !=
P.facets_end(); iter++ )
Polyhedron_id::Halfedge_around_facet_circulator j =
iter->facet_begin();
tris.push_back( CGAL::circulator_size(j) );
do
tris.push_back( std::distance(P.vertices_begin(),
j->vertex()) );
} while ( ++j != iter->facet_begin());
ret.initialize_load_from_mesh( coords, tris );
else
std::cout << "resulting polyhedron is not simple!" << std::endl;
return ret;
This time I triangulated my polygons before passing them into CGAL. Now at
the point where the problem shape is converted I get the following output:
252sqrt aCurrentCost Is 5.10207e-18 _tol is 0.001
252sqrt aCurrentCost Is 8.29476e-18 _tol is 0.001
252sqrt aCurrentCost Is 9.05531e-18 _tol is 0.001
252sqrt aCurrentCost Is 1.0065e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.11633e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.26797e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.36607e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.39187e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.43805e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.47533e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.49587e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.54581e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.59169e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.81504e-17 _tol is 0.001
252sqrt aCurrentCost Is 1.90392e-17 _tol is 0.001
252sqrt aCurrentCost Is 2.21188e-17 _tol is 0.001
252sqrt aCurrentCost Is 2.28058e-17 _tol is 0.001
252sqrt aCurrentCost Is 2.57659e-17 _tol is 0.001
252sqrt aCurrentCost Is 2.59503e-17 _tol is 0.001
252sqrt aCurrentCost Is 2.8387e-17 _tol is 0.001
252sqrt aCurrentCost Is 2.8972e-17 _tol is 0.001
252sqrt aCurrentCost Is 3.00493e-17 _tol is 0.001
252sqrt aCurrentCost Is 3.08919e-17 _tol is 0.001
252sqrt aCurrentCost Is 3.16258e-17 _tol is 0.001
252sqrt aCurrentCost Is 3.36404e-17 _tol is 0.001
252sqrt aCurrentCost Is 0.0257483 _tol is 0.001
Edges collected: 252
Edges processed: 27
Edges collapsed: 0
Edges not collapsed due to topological constriants: 5
Edge not collapsed due to cost computation constriants: 0
Edge not collapsed due to placement computation constriants: 0
Finished...
0 edges removed.
252 final edges.
Could you possibly give me some tips here? Why can't CGAL collapse the
edges, and what strategy should I take (or what am I doing
wrong/misunderstanding).
For info, below is the problem polyhedron again with the offending point
marked.
<http://cgal-discuss.949826.n4.nabble.com/file/n4659781/cgalprob.png>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-difference-on-Nef-polyhedron-produces-shape-with-duplicate-vertices-tp4659760p4659781.html
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/01/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, crobar, 09/01/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/04/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, crobar, 09/04/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/10/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, crobar, 09/15/2014
- Re: [cgal-discuss] CGAL difference on Nef_polyhedron produces shape with duplicate vertices, Sebastien Loriot (GeometryFactory), 09/22/2014
