cgal-discuss - Re: [cgal-discuss] Fwd: Make bad triangle mesh into nice Polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Fwd: Make bad triangle mesh into nice Polyhedron
  • Date: Wed, 10 Sep 2014 07:24:28 +0200
On 09/08/2014 03:02 PM, Per Zetterlund wrote:
You mean like poisson reconstruction? That is not what I'm after.
I need a way to eliminate the non-manifold edges and vertices
(without affecting the overall mesh).
Have a look into the file CGAL/orient_polygon_soup.h that is able to orient manifold polygon soups.
If you have non-manifold edges, you can modify the code to not stop
and create a new component for example.
Sebastien.
/Per
On Tue, Aug 26, 2014 at 7:50 PM, Zohar
wrote:
Surface reconstruction.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Fwd-Make-bad-triangle-mesh-into-nice-Polyhedron-tp4659744p4659745.html
