- To:
- Subject: Re: [cgal-discuss] Mesh Generation for Parametric Surface
- Date: Mon, 15 Sep 2014 06:44:45 -0700 (PDT)
Hey Zohar.
First of all forgive me my delayed response. Your idea with the subdivision
is really nice! But I don't want to miss some implemented functionality in
CGAL. I have seen this example
<http://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_implicit_sphere_8cpp-example.html>
for an implicit sphere, which seems to produce really accurate results with
only the implicit equation of the sphere as input. As you mentioned an
object that is described by a parametric form can be triangulated trivially.
Because of this I expect that CGAL should have some similar functions to
triangulate objects described by a parametric form. Can someone help me to
find it?
Thanks,
Markus
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-Generation-for-Parametric-Surface-tp4659822p4659842.html
- Re: [cgal-discuss] Mesh Generation for Parametric Surface, Zohar, 09/11/2014
- Re: [cgal-discuss] Mesh Generation for Parametric Surface, markus, 09/15/2014
- Re: [cgal-discuss] Mesh Generation for Parametric Surface, Zohar, 09/15/2014
- Re: [cgal-discuss] Mesh Generation for Parametric Surface, markus, 09/16/2014
