- To:
- Subject: [cgal-discuss] intersection of 2 3D objects
- Date: Mon, 15 Sep 2014 15:10:24 -0700
Hello
I'm want to compute the intersection of 2 3D objects. I want to decide whether there is significant overlap between the 2, to decide whether those are 2 observations of the same object. I imagined computing the intersection between the 2 convex hulls and measure the volume ratio between the intersection and one of the observations.
My raw input is a point cloud representation of the objects, which mostly samples the surface (e.g. 3D lidar representation, kinect, etc.). In order to get the volume, I can compute the convex hull for instance.
I looked at CGAL's doc, and found lots of methods to detect whether there is an intersection between 2 objects, where are the intersection points, what's the distance between the 2 objects, etc. (e.g. in the AABB tree component)
But I could not find a way to compute the intersecting volume. If I could get the intersection volume, I could compute what's the percentage of overlap. After doing some research, it appears that computing the volume of a polyhedron is not straightforward either...
Any suggestion would be appreciated.
Regards
Brice
- [cgal-discuss] intersection of 2 3D objects, Brice Rebsamen, 09/16/2014
- Re: [cgal-discuss] intersection of 2 3D objects, crobar, 09/16/2014
- Re: [cgal-discuss] intersection of 2 3D objects, Zohar, 09/17/2014
