- To:
- Subject: Re: [cgal-discuss] The triangle closest to a query point
- Date: Mon, 22 Sep 2014 12:58:27 -0700 (PDT)
Thank you so much Sebastien for your help.
I can get the vertex coordinates of the closest triangles by using:
std::cerr << "closest primitive is: " << *closest_primitive << std::endl;
which gives me the coordinates of all the three vertices constructing the
triangle, consecutively. How can I get the location of the points separately
instead of having them all together? (I guess it is an easy process, but I
am a beginner in both CGAL and C++) .
My other question is that then how can I know which points are involved with
this triangles? I mean in the same example, is there a way so I can know for
instance points a,b, and d are the ones that are making the closest triangle
to the query point without performing a search among all the points?
Vahid
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/The-triangle-closest-to-a-query-point-tp4659854p4659870.html
- [cgal-discuss] The triangle closest to a query point, vahid, 09/18/2014
- Re: [cgal-discuss] The triangle closest to a query point, Sebastien Loriot (GeometryFactory), 09/22/2014
- Re: [cgal-discuss] The triangle closest to a query point, vahid, 09/22/2014
- Re: [cgal-discuss] The triangle closest to a query point, Sebastien Loriot (GeometryFactory), 09/23/2014
- Re: [cgal-discuss] The triangle closest to a query point, vahid, 09/23/2014
- Re: [cgal-discuss] The triangle closest to a query point, Sebastien Loriot (GeometryFactory), 09/29/2014
