- To: <>
- Subject: Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata
- Date: Mon, 22 Sep 2014 17:09:13 +0100
Hello Sebastien, I made some more experiments and here are the results. First, the debug version for MSVS 2013. It seems to me that the fact that the release version works might be just a lucky coincidence. Please refer to the code attached (I tried to keep it as clean as possible and even removed any references to VTK, but maintained the overall iterator structure). What I witnessed when debugging is that the triangle returned for bbox computation (see AABB_traits.h, Line 356) is invalidated before the bbox() method is called. Diving deeper into the code I noticed that the problem (if it is in fact a problem) is in property_map.h, Line 54. The get() method accepts iterator by value, meaning in my case that the iterator is created, the within-iterator cache is created, and then upon return from get() function, the iterator is destroyed, making the cached triangle (returned by reference) invalid! When I changed this line to accept the iterator by const reference, the debug version also started working well. Note, that changing the Reference type in the iterator_facade to K::Triangle_3 also solves the problem (at some expense of performance I assume). For Linux version, however, this changes nothing, but something tells me that there is still something wrong with the iterator. I am completely lost what though. With Linux, I decided to start afresh and installed Ubuntu 14.04 LTS. The default compiler that comes with this version is gcc 4.8.2. Once I had no luck with it, I installed 4.9.1 although I don't think the compiler is the issue. As an additional measure, I removed the -std=c++11 flag (just in case). I have also used CGAL 4.5-beta1. I have attached the code with a #define within that show what I observe. Notice that this experiments use the Reference type of iterator_facade set to K::Triangle_3 (if SHOW_WORKING_VERSION is set to 0), so the aforementioned issue within property_map.h should have no effect. Basically the only code that doesn't hang for me is: when the Reference type of iterator_facade is left as default, and my iterator has the copy constructor which writes something about the _cache variable to the std::out. I would guess that this is a similar "lucky coincidence" as with the MSVS 2013 release version. Some combinations of writing to std::cout or not, having a copy constructor or not, and setting the Reference type to Value type or leaving it at Value& lead to seg fault, but something tells me that this is quite irrelevant. Anyway, what I would like to know is: does my iterator not satisfy some requirements of the AABB_Tree? Or perhaps my "proposed" change to property_map makes sense? Also, it seems to me that the whole thing with this caching iterator is pretty useless - originally I thought that it would help save memory (which it would if the triangles were to be built on the fly), but I think at least for now performance is more important for me. In this case, it would be easier and less code if I basically just converted the triangles from VTK to CGAL and stored them in an std::vector<K::Triangle_3> which would likely work just as fast and 100% correctly. Do you think this is correct? Thank you, Rostislav. On 22/09/2014 14:50, Sebastien Loriot
(GeometryFactory) wrote:
On 09/18/2014 08:08 PM, Khlebnikov, Rostislav wrote: |
// Author : Pierre Alliez
#include <iostream>
#include <list>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/AABB_tree.h>
#include <CGAL/AABB_traits.h>
#include <CGAL/AABB_triangle_primitive.h>
double coords[] = {
29.18630027770996, 174.8886260986328, -62.78001022338867,
28.372425079345703, 162.0009307861328, -65.0921859741211, 25.67314338684082,
174.9927520751953, -49.503562927246094,
0.2103467881679535, 159.42037963867188, -277.2245788574219,
13.64248275756836, 161.1861572265625, -276.2463073730469, 0.3464265763759613,
160.7919464111328, -264.30694580078125,
31.606674194335938, 159.23736572265625, -79.44971466064453,
24.031925201416016, 159.91285705566406, -88.17604064941406,
28.51704216003418, 174.669921875, -79.99639129638672,
-2.4768929481506348, 150.18797302246094, -108.59989929199219,
-12.030159950256348, 143.54347229003906, -109.60794830322266,
-10.126791954040527, 139.50340270996094, -98.82649230957031,
9.395136833190918, 134.27203369140625, -95.49534606933594,
-1.4869920015335083, 131.2742156982422, -93.83939361572266,
11.852248191833496, 129.7545623779297, -109.76504516601562,
-2.6369524002075195, 127.79691314697266, -124.92886352539062,
-11.963970184326172, 132.1261749267578, -109.15593719482422,
-11.131210327148438, 134.17269897460938, -120.17386627197266,
10.668848991394043, 194.10964965820312, -154.51881408691406,
10.066263198852539, 193.6329803466797, -171.33009338378906,
5.664018630981445, 191.9407196044922, -156.27230834960938,
11.698558807373047, 149.77438354492188, -67.33330535888672,
14.544828414916992, 142.69973754882812, -78.03868865966797,
25.19605255126953, 148.98193359375, -79.51082611083984,
-3.365452766418457, 146.0531463623047, -93.46614837646484,
1.8753833770751953, 152.99168395996094, -104.65605163574219,
1.7841202020645142, 130.89108276367188, -137.36697387695312,
15.414437294006348, 127.06056213378906, -123.71853637695312,
9.83181381225586, 192.99082946777344, -186.9521026611328,
13.714397430419922, 201.11087036132812, -170.16375732421875,
14.992523193359375, 145.1206817626953, -93.64944458007812,
28.755552291870117, 203.8203582763672, -93.77369689941406,
26.64963150024414, 204.46548461914062, -108.61288452148438,
18.69825553894043, 200.91824340820312, -110.31458282470703,
2.6021358966827393, 173.62451171875, -247.70054626464844,
-0.5297830104827881, 158.86598205566406, -252.25892639160156,
9.064677238464355, 163.0745849609375, -265.5377502441406,
32.49477005004883, 156.94677734375, -507.7084655761719,
34.496185302734375, 156.0312042236328, -521.6897583007812, 37.86516189575195,
156.7658233642578, -513.381103515625,
36.2860107421875, 151.49594116210938, -524.5477294921875,
34.496185302734375, 156.0312042236328, -521.6897583007812, 38.43404769897461,
152.02105712890625, -530.784423828125,
8.097879409790039, 187.4866485595703, -232.36233520507812,
4.315632343292236, 186.48275756835938, -231.96592712402344,
3.4246609210968018, 187.8110809326172, -217.2212371826172,
2.5345685482025146, 172.4355926513672, -262.2419738769531,
2.6021358966827393, 173.62451171875, -247.70054626464844, 8.077503204345703,
184.8253631591797, -247.26480102539062,
9.007757186889648, 161.76893615722656, -324.61798095703125,
3.429384708404541, 160.6028594970703, -323.5035705566406, 4.853285789489746,
168.54629516601562, -325.0062561035156,
-11.521470069885254, 149.80848693847656, -50.379573822021484,
-11.550424575805664, 157.72024536132812, -49.84595489501953,
-9.887701988220215, 154.5082244873047, -56.29947280883789,
5.960109233856201, 149.5780029296875, -358.83203125, 11.39888858795166,
158.1283416748047, -353.8124694824219, 10.722811698913574, 149.6037139892578,
-354.39154052734375,
10.422451972961426, 174.78964233398438, -263.82684326171875,
8.244054794311523, 174.72669982910156, -247.31585693359375,
40.070308685302734, 155.63668823242188, -523.67138671875, 36.2860107421875,
38.763797760009766, 175.7540283203125, -68.37883758544922,
39.341758728027344, 175.20016479492188, -76.29432678222656,
39.72635269165039, 190.09410095214844, -77.21231842041016,
-0.04478957876563072, 156.5264892578125, -60.68000411987305,
12.453887939453125, 160.12025451660156, -49.74186325073242,
13.793533325195312, 159.62319946289062, -63.151756286621094,
0.32879209518432617, 136.0102081298828, -84.23665618896484,
0.4302023947238922, 145.18849182128906, -78.6853256225586,
26.893264770507812, 193.40029907226562, -91.689453125,
-2.1577908992767334, 146.2375946044922, -266.4775695800781,
-1.99563467502594, 145.8889923095703, -274.2352600097656, 8.580360412597656,
142.18040466308594, -269.999267578125,
-1.4327821731567383, 147.3152313232422, -48.19434356689453,
40.070308685302734, 155.63668823242188, -523.67138671875, 37.86516189575195,
2.614022970199585, 160.56338500976562, -308.92919921875, 7.482606410980225,
167.59194946289062, -321.3027038574219,
8.33150863647461, 189.7926788330078, -217.17889404296875,
1.9665356874465942, 179.02220153808594, -218.0140380859375,
8.467718124389648, 179.02940368652344, -222.98666381835938,
40.298152923583984, 150.8389892578125, -526.1549682617188, 38.43404769897461,
2.074990749359131, 181.18576049804688, -205.4715576171875,
9.010037422180176, 191.89877319335938, -202.2879180908203, 2.887479782104492,
187.14349365234375, -201.91880798339844,
0.3464265763759613, 160.7919464111328, -264.30694580078125,
8.363688468933105, 149.29444885253906, -429.6105651855469,
-1.001146674156189, 146.45069885253906, -415.33294677734375,
-1.2460546493530273, 146.16213989257812, -430.76678466796875,
28.9470157623291, 189.64215087890625, -79.90576171875, 39.72635269165039,
190.09410095214844, -77.21231842041016, 37.976112365722656,
200.32350158691406, -79.22931671142578,
13.05890941619873, 161.63307189941406, -78.92259216308594, 4.964365005493164,
154.19720458984375, -79.58180236816406,
13.778759002685547, 146.31710815429688, -138.42466735839844,
13.977355003356934, 128.6435546875, -138.47573852539062, 1.7841202020645142,
-10.773425102233887, 134.0447540283203, -97.55136108398438,
4.964365005493164, 154.19720458984375, -79.58180236816406,
4.158769607543945, 190.48501586914062, -171.66477966308594,
3.241682529449463, 188.3593292236328, -187.84942626953125,
-19.546314239501953, 134.98312377929688, -339.40753173828125,
-18.855146408081055, 138.1035614013672, -354.1989440917969,
-19.420299530029297, 138.7296142578125, -338.2610168457031,
-18.971982955932617, 134.06002807617188, -354.68914794921875,
-19.820068359375, 134.29212951660156, -369.31573486328125,
-19.23091697692871, 137.72413635253906, -368.3957214355469,
13.977355003356934, 128.6435546875, -138.47573852539062, 25.288803100585938,
132.9503173828125, -128.03854370117188,
2.887479782104492, 187.14349365234375, -201.91880798339844,
14.681483268737793, 148.12326049804688, -123.89007568359375,
11.527284622192383, 144.68577575683594, -109.43207550048828,
10.133068084716797, 154.2608642578125, -415.2780456542969,
0.13050885498523712, 155.7189178466797, -430.0703125, 0.6555322408676147,
155.9097137451172, -415.5462646484375,
21.321714401245117, 201.83338928222656, -92.69882202148438,
13.465243339538574, 172.83975219726562, -276.4399108886719,
13.64248275756836, 161.1861572265625, -276.2463073730469, 9.064677238464355,
-2.286804676055908, 147.21705627441406, -124.9409408569336,
8.33150863647461, 189.7926788330078, -217.17889404296875, 2.887479782104492,
23.64198875427246, 196.23199462890625, -106.87743377685547,
15.198822975158691, 195.23143005371094, -124.12861633300781,
23.879322052001953, 204.50381469726562, -123.33671569824219,
17.010997772216797, 202.59329223632812, -124.53376007080078,
0.4510499835014343, 148.75099182128906, -444.157958984375,
1.124375820159912, 156.97035217285156, -446.11761474609375,
5.041719913482666, 158.33346557617188, -455.47528076171875,
-15.47876262664795, 147.13807678222656, -296.1484069824219,
-4.002422332763672, 149.16915893554688, -291.32452392578125,
0.8906582593917847, 159.33848571777344, -292.2961730957031,
29.18630027770996, 174.8886260986328, -62.78001022338867, 28.372425079345703,
12.997486114501953, 148.2761688232422, -369.91314697265625,
13.168941497802734, 146.0584716796875, -384.6397399902344,
12.536482810974121, 154.69451904296875, -384.7591247558594,
-2.4928367137908936, 124.77111053466797, -108.73846435546875,
39.72635269165039, 190.09410095214844, -77.21231842041016 };
int nCoords = sizeof(coords) / sizeof(coords[0]);
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
typedef K::Point_3 Point;
typedef K::Vector_3 Vector;
typedef K::Plane_3 Plane;
typedef K::Segment_3 Segment;
typedef K::Triangle_3 Triangle;
class Triangles_const_iterator
: public boost::iterator_facade<
, K::Triangle_3 const // Value
, boost::forward_traversal_tag // CategoryOrTraversal
// , K::Triangle_3 const // Reference
public:
Triangles_const_iterator()
: firstPointId(-1) {}
static Triangles_const_iterator begin()
return Triangles_const_iterator(0);
static Triangles_const_iterator end()
return Triangles_const_iterator(nCoords);
private:
explicit Triangles_const_iterator(int index)
: firstPointId(index)
_cache = createCache();
friend class boost::iterator_core_access;
void increment() {
firstPointId += 9;
K::Triangle_3 createCache()
if (firstPointId < nCoords) {
// Convert triangle to CGAL
return K::Triangle_3(
K::Point_3(coords[firstPointId + 0], coords[firstPointId +
1], coords[firstPointId + 2]),
K::Point_3(coords[firstPointId + 3], coords[firstPointId +
4], coords[firstPointId + 5]),
K::Point_3(coords[firstPointId + 6], coords[firstPointId +
7], coords[firstPointId + 8]));
return K::Triangle_3();
K::Triangle_3 const& dereference() const { return _cache; }
bool equal(Triangles_const_iterator const& other) const
return firstPointId == other.firstPointId;
int firstPointId;
K::Triangle_3 _cache;
typedef CGAL::AABB_triangle_primitive<K, Triangles_const_iterator> Primitive;
typedef CGAL::AABB_traits<K, Primitive> Traits;
typedef CGAL::AABB_tree<Traits> Tree;
int main()
Point points[] = { Point(13.961, 167.000, -286.0), Point(13.500, 0,
-286.5), Point(13.000, 167.500, 0) };
Vector normal = CGAL::cross_product<K>(points[2] - points[0], points[1] -
points[0]);
normal = normal / sqrt(normal.squared_length());
std::cout << "Building tree\n";
Triangle t(Point(0, 0, 0), Point(0, 1, 0), Point(1, 1, 0));
CGAL::Bbox_3 b = t.bbox();
Tree tree(Triangles_const_iterator::begin(),
Triangles_const_iterator::end());
tree.build();
std::cout << "Done\n";
// counts #intersections with a plane query
Plane plane_query(points[0], normal);
std::vector<Tree::Intersection_and_primitive_id<Plane>::Type> segments;
tree.all_intersections(plane_query, std::back_inserter(segments));
std::cout << segments.size() << " intersections(s) with plane\n";
return EXIT_SUCCESS;
#include <iostream>
#include <list>
double coords[] = {
typedef K::FT FT;
// If set to 0, the original hang will be shown
#define SHOW_WORKING_VERSION 1
#if !SHOW_WORKING_VERSION
, K::Triangle_3 // Reference
#endif
public:
: Triangles_const_iterator::iterator_facade_()
, firstPointId(-1) {}
#if SHOW_WORKING_VERSION
Triangles_const_iterator(const Triangles_const_iterator& other)
: Triangles_const_iterator::iterator_facade_(other)
firstPointId = other.firstPointId;
_cache = other._cache;
//std::cout << _cache.vertex(0).x() << " ";
#endif // SHOW_WORKING_VERSION
private:
, firstPointId(index)
void increment() {
firstPointId += 9;
if (firstPointId >= 0 && firstPointId < nCoords) {
int firstPointId;
typedef CGAL::AABB_triangle_primitive<K, Triangles_const_iterator,
CGAL::Tag_true> Primitive;
int main()
points[0]);
tree.build();
std::cout << "\n\n" << segments.size() << " intersections(s) with
plane\n";
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 09/18/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Khlebnikov, Rostislav, 09/18/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Sebastien Loriot (GeometryFactory), 09/22/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 09/22/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Sebastien Loriot (GeometryFactory), 09/23/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 09/23/2014
