- To:
- Subject: [cgal-discuss] convex_hull_3 generates polyhedron with equal points
- Date: Wed, 24 Sep 2014 21:09:09 +0400
- Envelope-from:
Hi,
I'm using convex_hull_3 with Exact_predicates_inexact_constructions_kernel.
The function returns polyhedron with the following vertices:
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #0: (-8.660254e-01, -5.000000e-01, 0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #1: (-8.660254e-01, -5.000000e-01, -0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #2: (-0.000000e+00, -0.000000e+00, 1.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #3: (-0.000000e+00, -0.000000e+00, -1.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #4: (-0.000000e+00, -1.000000e+00, -0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #5: (-8.660254e-01, 5.000000e-01, -0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #6: (-8.660254e-01, 5.000000e-01, -0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #7: (8.660254e-01, 5.000000e-01, -0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #8: (8.660254e-01, 5.000000e-01, 0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #9: (8.660254e-01, -5.000000e-01, -0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #10: (-0.000000e+00, 1.000000e+00, -0.000000e+00)
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point #11: (8.660254e-01, -5.000000e-01, -0.000000e+00)
As you can see some of points are equal, and this makes its analysis complex.
Is there any setting in convex_hull_3 that can help to avoid such situation?
Best regards,
Ilya Palachev
- [cgal-discuss] convex_hull_3 generates polyhedron with equal points, Илья Палачев, 09/24/2014
- Re: [cgal-discuss] convex_hull_3 generates polyhedron with equal points, Andreas Fabri, 09/24/2014
