- To:
- Subject: Re: [cgal-discuss] convex_hull_3 generates polyhedron with equal points
- Date: Wed, 24 Sep 2014 20:00:25 +0200
Just increase the precision.
std::cout.precision(17);
before you write the points to the stream.
http://www.cplusplus.com/reference/iomanip/setprecision/
best,
andreas
On 24/09/2014 19:09, Илья Палачев wrote:
Hi,
I'm using convex_hull_3 with Exact_predicates_inexact_constructions_kernel.
The function returns polyhedron with the following vertices:
[Polyhedron_3 convexHullCGAL(CGALpointsSet): 594]: convex hull's point
#0: (-8.660254e-01, -5.000000e-01, 0.000000e+00)
#1: (-8.660254e-01, -5.000000e-01, -0.000000e+00)
#2: (-0.000000e+00, -0.000000e+00, 1.000000e+00)
#3: (-0.000000e+00, -0.000000e+00, -1.000000e+00)
#4: (-0.000000e+00, -1.000000e+00, -0.000000e+00)
#5: (-8.660254e-01, 5.000000e-01, -0.000000e+00)
#6: (-8.660254e-01, 5.000000e-01, -0.000000e+00)
#7: (8.660254e-01, 5.000000e-01, -0.000000e+00)
#8: (8.660254e-01, 5.000000e-01, 0.000000e+00)
#9: (8.660254e-01, -5.000000e-01, -0.000000e+00)
#10: (-0.000000e+00, 1.000000e+00, -0.000000e+00)
#11: (8.660254e-01, -5.000000e-01, -0.000000e+00)
As you can see some of points are equal, and this makes its analysis
complex.
Is there any setting in convex_hull_3 that can help to avoid such situation?
Best regards,
Ilya Palachev
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] convex_hull_3 generates polyhedron with equal points, Илья Палачев, 09/24/2014
- Re: [cgal-discuss] convex_hull_3 generates polyhedron with equal points, Andreas Fabri, 09/24/2014
