- To:
- Subject: Re: [cgal-discuss] Surface_reconstruction_points_3 compilation error
- Date: Fri, 3 Oct 2014 00:39:10 -0700
1.55 - I tried a couple boost versions based on the error messages, is
there a preferred version?
Thanks!
> On 10/03/2014 09:18 AM,
> wrote:
>> Hello,
>> I am a new user and have tried to compile this example from a number of
>> CGAL releases, I have also installed the requirements and "reinstalled"
>> boost... Can someone please help me out? I'm not quite sure what the
>> hang-up is. Thank you in advance!
> Look like a pb with the boost library. What version are you using?
> Sebastien.
>> kc
>> ~/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3$ make
>> Scanning dependencies of target poisson_reconstruction
>> [ 50%] Building CXX object
>> CMakeFiles/poisson_reconstruction.dir/poisson_reconstruction.cpp.o
>> In file included from /usr/include/boost/thread/pthread/mutex.hpp:14:0,
>> from /usr/include/boost/thread/mutex.hpp:16,
>> from
>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/Kd_tree.h:34,
>> from
>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/internal/K_neighbor_search.h:28,
>> from
>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/Orthogonal_k_neighbor_search.h:24,
>> from
>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/internal/AABB_tree/AABB_search_tree.h:24,
>> from
>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/AABB_tree.h:28,
>> from
>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/poisson_reconstruction.cpp:12:
>> /usr/include/boost/thread/xtime.hpp:23:5: error: expected identifier
>> before numeric constant
>> /usr/include/boost/thread/xtime.hpp:23:5: error: expected } before
>> numeric constant
>> /usr/include/boost/thread/xtime.hpp:23:5: error: expected unqualified-id
>> /usr/include/boost/thread/xtime.hpp:46:14: error: expected
>> type-specifier
>> before system_time
>> from
>> from
>> from
>> from
>> from
>> from
>> /usr/include/boost/thread/xtime.hpp: In function int xtime_get(xtime*,
>> int):
>> /usr/include/boost/thread/xtime.hpp:73:40: error: get_system_time was
>> not declared in this scope
>> /usr/include/boost/thread/xtime.hpp:73:40: note: suggested alternative:
>> In file included from /usr/include/boost/thread/locks.hpp:12:0,
>> from /usr/include/boost/thread/pthread/mutex.hpp:12,
>> from
>> from
>> from
>> from
>> from
>> from
>> /usr/include/boost/thread/thread_time.hpp:19:24: note:
>> boost::get_system_time
>> from
>> from
>> from
>> from
>> from
>> from
>> /usr/include/boost/thread/xtime.hpp: At global scope:
>> /usr/include/boost/thread/xtime.hpp:88:1: error: expected declaration
>> before } token
>> make[2]: ***
>> [CMakeFiles/poisson_reconstruction.dir/poisson_reconstruction.cpp.o]
>> Error
>> 1
>> make[1]: *** [CMakeFiles/poisson_reconstruction.dir/all] Error 2
>> make: *** [all] Error 2
>> kc@oblivion-tre:~/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3$
>> make
>> from
>> from
>> from
>> from
>> from
>> from
>> numeric constant
>> type-specifier
>> before system_time
>> from
>> from
>> from
>> from
>> from
>> from
>> int):
>> from
>> from
>> from
>> from
>> from
>> from
>> from
>> from
>> from
>> from
>> from
>> from
>> before } token
>> make[2]: ***
>> Error
>> 1
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Surface_reconstruction_points_3 compilation error, kevnull, 10/03/2014
- Re: [cgal-discuss] Surface_reconstruction_points_3 compilation error, Sebastien Loriot (GeometryFactory), 10/03/2014
- Re: [cgal-discuss] Surface_reconstruction_points_3 compilation error, kevnull, 10/03/2014
- Re: [cgal-discuss] Surface_reconstruction_points_3 compilation error, kevnull, 10/04/2014
