cgal-discuss - Re: [cgal-discuss] Surface_reconstruction_points_3 compilation error
  • To:
  • Subject: Re: [cgal-discuss] Surface_reconstruction_points_3 compilation error
  • Date: Fri, 3 Oct 2014 01:57:55 -0700
So I downloaded boost 1.56 and copied boost into /usr/local/include/
and now when I try and compile the example I get:
~/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3$ make
make[2]: *** No rule to make target `/usr/local/lib/libCGAL.so', needed by
`poisson_reconstruction'. Stop.
make[1]: *** [CMakeFiles/poisson_reconstruction.dir/all] Error 2
make: *** [all] Error 2
Thoughts? CGAL itself compiles just fine?
> On 10/03/2014 09:39 AM,
> wrote:
>> 1.55 - I tried a couple boost versions based on the error messages, is
>> there a preferred version?
> In the file boost/thread/xtime.hpp of boost 1.55 I have
> 22: enum xtime_clock_types
> 23: {
> 24: TIME_UTC_=1
> No idea why you have such an error.
> Sebastien.
>> Thanks!
>>> On 10/03/2014 09:18 AM,
>>> wrote:
>>>> Hello,
>>>> I am a new user and have tried to compile this example from a number
>>>> of
>>>> CGAL releases, I have also installed the requirements and
>>>> "reinstalled"
>>>> boost... Can someone please help me out? I'm not quite sure what the
>>>> hang-up is. Thank you in advance!
>>> Look like a pb with the boost library. What version are you using?
>>> Sebastien.
>>>> kc
>>>> Scanning dependencies of target poisson_reconstruction
>>>> [ 50%] Building CXX object
>>>> CMakeFiles/poisson_reconstruction.dir/poisson_reconstruction.cpp.o
>>>> In file included from
>>>> /usr/include/boost/thread/pthread/mutex.hpp:14:0,
>>>> from /usr/include/boost/thread/mutex.hpp:16,
>>>> from
>>>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/Kd_tree.h:34,
>>>> from
>>>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/internal/K_neighbor_search.h:28,
>>>> from
>>>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/Orthogonal_k_neighbor_search.h:24,
>>>> from
>>>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/internal/AABB_tree/AABB_search_tree.h:24,
>>>> from
>>>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/../../include/CGAL/AABB_tree.h:28,
>>>> from
>>>> /home/kc/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3/poisson_reconstruction.cpp:12:
>>>> /usr/include/boost/thread/xtime.hpp:23:5: error: expected identifier
>>>> before numeric constant
>>>> /usr/include/boost/thread/xtime.hpp:23:5: error: expected ‘}’ before
>>>> numeric constant
>>>> unqualified-id
>>>> /usr/include/boost/thread/xtime.hpp:46:14: error: expected
>>>> type-specifier
>>>> before ‘system_time’
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> /usr/include/boost/thread/xtime.hpp: In function ‘int
>>>> xtime_get(xtime*,
>>>> int)’:
>>>> /usr/include/boost/thread/xtime.hpp:73:40: error: ‘get_system_time’
>>>> was
>>>> not declared in this scope
>>>> /usr/include/boost/thread/xtime.hpp:73:40: note: suggested
>>>> alternative:
>>>> In file included from /usr/include/boost/thread/locks.hpp:12:0,
>>>> from
>>>> /usr/include/boost/thread/pthread/mutex.hpp:12,
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> /usr/include/boost/thread/thread_time.hpp:19:24: note:
>>>> ‘boost::get_system_time’
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> /usr/include/boost/thread/xtime.hpp: At global scope:
>>>> /usr/include/boost/thread/xtime.hpp:88:1: error: expected declaration
>>>> before ‘}’ token
>>>> make[2]: ***
>>>> [CMakeFiles/poisson_reconstruction.dir/poisson_reconstruction.cpp.o]
>>>> Error
>>>> 1
>>>> kc@oblivion-tre:~/src/CGAL/CGAL-4.4/examples/Surface_reconstruction_points_3$
>>>> make
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> numeric constant
>>>> unqualified-id
>>>> type-specifier
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> xtime_get(xtime*,
>>>> int)’:
>>>> was
>>>> alternative:
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> from
>>>> before ‘}’ token
>>>> make[2]: ***
>>>> Error
>>>> 1
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://sympa.inria.fr/sympa/info/cgal-discuss
