- To:
- Subject: [cgal-discuss] Point .... dim=1 form an edge but do not intersect
- Date: Tue, 07 Oct 2014 17:12:25 +0200
Hey Guys,
I get the error:
Point p[-9.91211 -13.5246 -10.8856], dim=1 and q[-9.9571 -13.5666 -10.9184],
dim=1 form an edge but do not intersect !
CGAL error: assertion violation!
Expression : minimal_size_ > 0 || c3t3_.is_valid()
File : /opt/local/include/CGAL/Mesh_3/Protect_edges_sizing_field.h
Line : 370
and stumbled on this link:
http://cgal-discuss.949826.n4.nabble.com/Problem-when-meshing-polyhedron-with-sharp-features-td4659217.html
Are those issues solved in CGAL 4.4_0?
If so, what might be causing this? The stl used
was checked with MeshLab to be singly connected,
but has same very sharp features and "tunnels".
Thank you for any assistance.
Regards,
Ruud
- [cgal-discuss] Point .... dim=1 form an edge but do not intersect, Ruud Vlaming, 10/07/2014
- Re: [cgal-discuss] Point .... dim=1 form an edge but do not intersect, Laurent Rineau (CGAL/GeometryFactory), 10/08/2014
- Re: [cgal-discuss] Point .... dim=1 form an edge but do not intersect, Ruud Vlaming, 10/08/2014
